, Exploiting locality in distributed sdn control», dans Proceedings of the Second ACM SIGCOMM Workshop on Hot Topics in Software Defined Networking, HotSDN '13, pp.121-126, 2013.
, Cloud computing with open source tool :openstack», vol.3, pp.233-240, 2014.
, , pp.1344-1351, 2017.
«Multi-objective multi-constrained qos routing in large-scale networks: A genetic algorithm approach, dans 2018 International Conference on Smart Communications in Network Technologies (SaCoNeT), pp.55-60, 2018. ,
«K-means++: The advantages of careful seeding, dans Proceedings of the Eighteenth Annual ACM-SIAM Symposium on Discrete Algorithms, SODA '07, pp.1027-1035, 2007. ,
Hypervolume-based multiobjective optimization: Theoretical foundations and practical implications, », Theor. Comput. Sci, vol.425, pp.75-103, 2012. ,
URL : https://hal.archives-ouvertes.fr/inria-00638989
Approximation algorithms for selecting network centers, pp.343-354, 1991. ,
«Approximation algorithms for selecting network centers (preliminary vesion).», dans WADS, Lecture Notes in Computer Science, vol.519, pp.343-354, 1991. ,
, , vol.252, pp.31-45, 2002.
«The average connectivity of a graph, Discrete Mathematics, vol.252, issue.1, pp.31-45, 2002. ,
«An nsga-iii algorithm for solving multi-objective economic/environmental dispatch problem, Cogent Engineering, vol.3, issue.1, 2016. ,
«A faster algorithm for betweenness centrality», Journal of Mathematical Sociology, vol.25, pp.163-177, 2001. ,
«Algorithm 457: Finding all cliques of an undirected graph, Commun. ACM, vol.16, pp.575-577, 1973. ,
«A nsga-ii and nsga-iii comparison for solving an open shop scheduling problem with resource constraints, 8th IFAC Conference on Manufacturing Modelling, Management and Control MIM, vol.49, pp.1272-1277, 2016. ,
«Quality-of-service routing for supporting multimedia applications», IEEE Journal on Selected Areas in Communications, vol.14, issue.7, pp.733-8716, 1996. ,
A fast and elitist multiobjective genetic algorithm: Nsga-ii, IEEE Transactions on Evolutionary Computation, vol.6, issue.2, pp.182-197, 2002. ,
«Theoretical improvements in algorithmic efficiency for network flow problems, J. ACM, vol.19, issue.2, pp.248-264, 1972. ,
«A density-based algorithm for discovering clusters a density-based algorithm for discovering clusters in large spatial databases with noise, dans Proceedings of the Second International Conference on Knowledge Discovery and Data Mining, KDD'96, pp.226-231, 1996. ,
Computers and Intractability; A Guide to the Theory of NP-Completeness, 1990. ,
Applying evolutionary algorithms to machine learning techniques, ACM International Joint Conferences on Web Intelligence (WI) and Intelligent Agent Technologies (IAT) -Volume 02, WI-IAT '14, pp.449-453, 2014. ,
, Experience with a globally-deployed software defined wan», SIGCOMM Comput, vol.4, p.4, 2013.
, Reducibility among combinatorial problems», dans Complexity of Computer Computations, pp.85-103, 1972.
, dans 50 Years of Integer Programming
«Reducibility among combinatorial problems», dans 50 Years of Integer Programming 1958-2008 -From the Early Years to the State-of-the-Art, pp.219-241, 2010. ,
«Varying environments can speed up evolution, Proceedings of the National Academy of Sciences, vol.104, pp.13-711, 2007. ,
«A multi-objective non-dominated sorting genetic algorithm for vnf chains placement, 15th IEEE Annual Consumer Communications Networking Conference (CCNC), pp.1-4, 2018. ,
«A multiobjective heuristic for the optimization of virtual network function chain placement, 29th International Teletraffic Congress (ITC 29), vol.1, pp.152-160, 2017. ,
, Redesigning the jmetal multi-objective optimization framework», dans Proceedings of the Companion Publication of the, 2015.
, Annual Conference on Genetic and Evolutionary Computation, GECCO Companion '15, pp.1093-1100
, Towards a standard cp modelling language.», dans CP, vol.4741, pp.529-543
, Towards a standard cp modelling language», dans Proceedings of the 13th International Conference on Principles and Practice of Constraint Programming, CP'07, pp.529-543
«Application of evolutionary mechanism to dynamic virtual network function placement, IEEE 24th International Conference on Network Protocols (ICNP), pp.1-6, 2016. ,
«Virtual network function forwarding graph embedding: A genetic algorithm approach, Saconet speical issues, 2018. ,
«Video streaming over ad hoc networks: A qoe-based optimal routing solution, IEEE Transactions on Vehicular Technology, vol.66, issue.2, pp.1533-1546, 2017. ,
«A bit error rate analysis for tcp traffic over parallel free space photonics, Telecommunication Systems, vol.56, issue.4, pp.455-466, 2014. ,
Optimisation combinatoire: Programmation discrète, Collection Enseignement des sciences, 1984. ,
Gpgpu-compatible archive based stochastic ranking evolutionary algorithm (g-asrea) for multi-objective optimization», dans Parallel Problem Solving from Nature, pp.111-120, 2010. ,
, The minizinc challenge, vol.35, pp.55-60, 2008.
, Constraint Propagation -Models, Techniques, Implementation, 2009.
«Concepts of exact qos routing algorithms, IEEE/ACM Transactions on Networking, vol.12, issue.5, pp.851-864, 2004. ,
Twas brillig, and the slithy toves Did gyre and gimble in the wabe: All mimsy were the borogoves, And the mome raths outgrabe, «SPEA2: Improving the strength pareto evolutionary algorithm for multiobjective optimization», dans Evolutionary Methods for Design Optimization and Control with Applications to Industrial Problems, pp.95-100, 2001. ,
, Evolvability from learning algorithms», dans Proceedings of the Fortieth Annual ACM Symposium on Theory of Computing, STOC '08, pp.619-628, 2008.
Probably Approximately Correct: Nature's Algorithms for Learning and Prospering in a Complex World, p.9780465032716, 2013. ,
