Condensation and evaporation of hexane in porous alumina membranes
Condensation et évaporation de l'hexane dans les membranes d'alumine poreuse
This manuscript presents a study of condensation and evaporation mechanisms in porous alumina membranes. This porous material has almost cylindrical pores of nanometric diameter with a narrow pore size distribution. Unlike many other porous media, their pores are not interconnected. Porous alumina is therefore an ideal material to probe the effects of confinement on condensation and evaporation in a single pore.The first part discusses my results obtained on membranes with straight pores open at both extremities or closed at one side. Sorption isotherms using hexane coupled to an original study of the membranes optical behaviour allow us to probe the liquid distribution within the pores. The results show that our pores are not perfectly cylindrical but funnel shaped and present corrugations. I numerically reproduced the measured isotherms with a cellular automaton, which takes into account the pores defects. This agreement implies that condensation and evaporation in a single pore are properly described by Saam & Cole theory.The second part evidences evaporation by cavitation in porous alumina membranes. A specific synthesis protocol is used to produce membranes with ink-bottle shaped pores. These membranes undergo a systematic and sudden emptying at 0.33 Psat, as measured by the optic and volumetric signals. This is the signature of the homogeneous cavitation of the liquid contained inside the ink-bottles, i.e. the nucleation of a spherical gas bubble in a liquid under tension. This is the first direct observation of such an evaporation process in porous membranes.
Ce manuscrit présente une étude des mécanismes de condensation et d'évaporation dans des membranes d'alumine poreuse. Ce matériau poreux possède des pores quasi-cylindriques de taille nanométrique faiblement distribués en diamètres qui, contrairement à beaucoup d'autres milieux poreux, ne sont pas interconnectés. L'alumine poreuse est donc un milieu idéal pour sonder l'influence du confinement sur la condensation et l'évaporation à l'échelle du pore unique.La première partie discute mes résultats dans des membranes disposant de pores droits ouverts aux deux extrémités ou fermés d'un côté. Des mesures d'isothermes de sorption à l'hexane couplées à une étude originale du comportement optique des membranes pour sonder la répartition du liquide dans les pores, indiquent ces derniers ne sont pas parfaitement cylindriques, mais ont une forme conique et possèdent des corrugations marquées. En tenant compte de ces imperfections grâce à des simulations par automate cellulaire, j'ai pu reproduire numériquement les isothermes mesurées. Cet accord montre que la théorie de Saam & Cole décrit bien la condensation et l'évaporation dans un pore unique.La seconde partie met en évidence l'évaporation par cavitation dans les membranes d'alumine poreuse. Un protocole de synthèse spécifique m'a permis d'obtenir des membranes avec des pores en forme d'encrier. Dans ces dernières, j'ai systématiquement observé, optiquement et volumétriquement, une vidange brutale des pores à 0.33 Psat.Celle-ci correspond à la cavitation homogène de l'hexane dans les cavités des encriers, c'est-à-dire à la nucléation thermiquement activée d'une bulle de gaz sphérique dans le liquide sous tension. Il s'agit de la première observation directe d'un tel mécanisme d'évaporation dans des membranes poreuses.
