Contributions to the safe and efficient parallelisation of hard real-time systems
Contributions à la parallélisation sûre et efficace de systèmes temps réel durs
We propose an automatic parallelization method for applications featuring
fine-grain internal parallelism. Our method adds the needed overheads to the
WCET values, ensuring safety by construction without the need for subsequent
schedulability analysis. It is aimed at applications with fine-grain parallelism
where excessive per-task overheads would result in poor parallelization gains.
To keep overheads under control, we make strong
hypotheses on the target execution platform, on the form of generated code, and
on the integration of the various tools of the back-end. These hypotheses allow
our tool-flow to perform a full-fledged timing and schedulability analysis
incrementally during allocation and scheduling. Allocation and scheduling are
performed jointly, using scalable compilation-like heuristics. The resulting
schedule and code are correct by construction.
By covering all aspects of resource allocation and code generation, our work
belongs to the compilation realm. What fundamentally differentiates it from
previous compilation work is the choice of performing a safe, worst-case
timing analysis incrementally during compilation around which are
integrated parallelization, real-time scheduling, and memory allocation. This
method is suitable for very large-scale applications, as it uses low-complexity
mapping heuristics, which guarantees scalability.
We also propose a language, named InteLus, for the description of parallel
multi-threaded implementations of dataflow specifications. It is a sub-set of
Lustre extended with annotations representing mapping and code generation
choices. While such extensions are common in literature, our language and
modeling approach go further in one fundamental way: implementation models
specified in InteLus are strictly richer than the multi-threaded C code
we want to generate. InteLus allows the representation of all mapping
decisions needed for multi-threaded code generation in our context. InteLus'
representation of threads and thread synchronization is a sub-case of the
C11/pthread concurrency model. Therefore, C code can be obtained by selectively
putting elements of the InteLus program into C and linker script syntax
without making any further mapping decision. Annotations are covered by the
operational semantics of InteLus. This allows us to formally define the
correctness of implementation models. To facilitate the definition of the
correctness properties, implementation models are endowed with not one, but two
semantics: the synchronous semantics of Lustre (which simply discards
mapping annotations) and the machine semantics, which interprets the
program and its annotations as a multi-threaded imperative program. This dual
semantic nature of our implementation models enables us to envision an original
approach to proving implementation correctness.
Nous proposons une méthode de parallélisation automatique à grain fin pour des applications temps réel.
