Abstract : This doctoral thesis deals with documented Iron Age habitats on the territory of presentday Kosovo, which represents an area of 10 887 km², corresponding to the central part of the ancient Dardania which also extended to the south from Serbia, north of Macedonia, to the northeast of Albania. This dissertation is divided in two main parts). (In the first part is presentedcatalog of all sites), excavated or not, known to date, classified by typology and size, accompanied by a description of the characteristics of the habitats and archaeological materials, to establish their chronology. The corpus comprises a total of 45 habitats, of which 29 have been excavated. On the basis of the material studied, the chronology can be divided into four phases: The oldest XI-IX century BC. J.-C, is a transition phase between the recent Bronze and the old Iron; then the Iron Age is divided into two periods: the first phase of the Iron Age (8th-7th centuries BC), and the second phase of the Iron Age (6th - 4th century BC); the last phase corresponds to the Hellenistic period until the arrival of the Romans (IV-I centuries BC). Thesecond part provides a summary of the 1. Typology and distribution of inhabited areas, taking into account their relationship with necropolises, 2. The extent of habitats and their architectural features, and 3. The material culture they harbored. Three types of habitats were identified: highrise habitats, terrace dwellings and lowland habitats; these habitats can be grouped into four regions, with the exception of the Valaç habitat, which remains an isolated case in the north of the country; in each region, the sites are visible from each other. The necropolises, 51 in total, also occupy an important place. There are two types of necropolis: the tumular necropolises - the most numerous, and the non-tumular necropolises. For both types, their main characteristics, distribution, chronology, funerary rites and their relation to habitats were studied. The second chapter made it possible to establish a hierarchy of habitats according to their size, to distinguish four types of fortification, and to present the first known plans of Dardanian huts. The last chapter of the thesis studies the dishes and the objects of domestic life. For each chronological phase, the nature of the pasta and the characteristic forms that make it possible to follow the continuities and the innovations are given. The material studied shows that, alongside food storage and food preparation, metallurgical and weaving activities are also important. Finally, the importation and local imitation of Greek vases related to the consumption of wine, present in the habitats as in the necropolises, poses the problem of the adoption of the practice of the "symposion".
Résumé : Cette thèse de doctorat traite des habitats de l'Âge du fer documentés sur le territoire de l’actuel Kosovo, qui représente une superficie de 10 887 km², il correspond à la partie centrale de l'ancienne Dardanie qui s’étendait aussi au sud de la Serbie, au nord de la Macédoine, au nord-est de l'Albanie. Le travail s’organise en deux parties principales. La première est le catalogue recensant tous les sites, fouillés ou non, connus à ce jour, classés par typologie et par taille, accompagnés d’une description des caractéristiques de l'habitat et du matériel archéologique permettant d’établir leur chronologie. Le corpus comprend un total de 45 habitats, dont 29 ont fait l’objet de fouilles. Sur la base du matériel étudié, la chronologie peut être divisée en quatre phases : la plus ancienne XIe-IXe siècle av. J.-C, est une phase de transition entre le Bronze récent et le Fer ancien ; puis l’Âge du fer proprement dit est divisé en deux périodes, la première phase de l’Âge du fer (VIIIe-VIIe siècles av. J.-C.), et la deuxième phase de l’Âge du fer (VIe-IVe siècles av. J.-C.) ; la dernière phase correspond à la période hellénistique jusqu’à l’arrivée des Romains (IVe-Ie siècles av. J.-C.).La deuxième partie propose des éléments de synthèse qui traite 1. de la typologie et de la répartition des zones habitées, en prenant en compte leurs relations avec les nécropoles, 2. de l’étendue des habitats et de leurs caractéristiques architecturales, et 3. de la culture matérielle qu’ils abritent. On a ainsi pu identifier trois types d’habitats : les habitats de hauteur, ceux sur terrasse et les habitats en plaine ; ces habitats peuvent être regroupés en quatre régions, à l'exception de l'habitat de Valach qui reste un cas isolé dans le nord du pays ; dans chaque région, les sites sont visibles les uns des autres. Les nécropoles, 51 au total, occupent également une place importante. Il y a deux types de nécropoles : les nécropoles tumulaires, les plus nombreuses, et les nécropoles non tumulaires. Pour les deux types, on a étudié leurscaractéristiques principales, leur répartition, la chronologie, les rites funéraires et leur relation avec les habitats. Le deuxième chapitre a permis d’établir une hiérarchie des habitats en fonction de leur taille, de distinguer quatre types de fortification, et de présenter les premiers plans connus de cabanes dardaniennes. Le dernier chapitre de la thèse étudie la vaisselle et les objets de la vie domestique. Pour chaque phase chronologique, sont données la nature des pâtes et les formes caractéristiques qui permettent de suivre les continuités et les innovations. Le matériel étudié montre qu’à côté du stockage de denrées et de la préparation des aliments, les activités métallurgiques et de tissage sont aussi importantes. Enfin l’importation et l’imitation locale des vases grecs liés à la consommation du vin, présents dans les habitats comme dans les nécropoles, pose le problème de l’adoption de la pratique du "symposion".
