Estudo das substâncias húmicas em pedo-paisagem podzolizada na bacia do Alto Rio Negro- AM, Brasil - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Humic substances in podzolized pedo-landscape in the Upper Negro River, Brazil : characterization of fulvic and humic acids in soil and distribution complexing capacity with metal
Les différences entre les Podzols épais hydromorphiques et les cryptopodzols du bassin du Rio Negro (Amazonie, Brésil) étude de la caractérisation de la matière organique par spectroscopie : étude de la caractérisation de la matière organique par spectroscopie
The purpose of this study is understaning the behavior of fulvic and humic acid fractions in a podzolized soilssystem, taking into account soils characteristics and to investigate the complexing capacity of Cu + 2 and Al + 3.For this purpose, conventional pedology and spectroscopic methods, Uv-Visible absorbance Spectroscopy, FourierTransform Infrared Spectrometry (FTIR) and Quenching Fluorescence using the CP/PARAFAC treatment wereused to achieve the objectives: (i) to determine the stages of transformation of the pedo-landscape through thestudy of soils and the spatial distribution of podzolized soils and gleysol in a drainage basin; (ii) to characterize SHand to understand the distribution patterns of fulvic and humic acids in a podzolized soil sequence along a slopeand in the horizons along the soil profiles taking into account the morphological characteristics, texture, pH, carbontotal and groundwater variation in the horizons of the soils of a sequence of podzols soils; (iii) to study thecomplexing capacity of humic substances (fulvic and humic acids) of podium soils samples in the Alto Rio NegroBasin, by identifying the fluorescent components of humic substances, evaluating capacities and complexingconstants of these substances with the Cu + 2 and Al + 3 metals, and the comparison with the functional groupsobtained with FTIR. Although fulvic acids are more aromatic and condensed their character is predominantlyaliphatic and hydrophilic and secondarily aromatic and carboxylic. Humic acids are less aromatic and lesscondensed than fulvic acids and are characterized by polysaccharide and ether/alcohol functions, but secondarilytheir character is aliphatic and hydrophilic. These differences are related to the presence of the functional groupsthat are responsible for the differences in the complexation dynamics of the metals, in the humic acids complexesCu+ 2 and Al+ 3 are associated with the functional groups ether/alcohol and CO polysaccharides while in the fulvicacids the correlation is greatest with the functional groups -CH, -OH and carboxylic COOH.
Le but de cette étude était de comprendre le comportement des fractions d'acide fulvique et d'acide humiquedans un système de sols podzolisé, compte tenu des caractéristiques du sol et d'étudier la capacité decomplexation de Cu+ 2 et Al + 3 dans des échantillons de ces sols. Pour cela, les méthodes conventionnellesde pédologie et de Spectroscopie de l'absorbance UV-Visible, Spectroscopie Infrarouge à Transformée deFourier et Fluorescence Quenching avec le traitement CP / PARAFAC ont été utilisés pour atteindre lesobjectifs suivants: (i) déterminer les étapes de transformation du pedo-paysage à l'étude des sols et à larépartition spatiale des sols podzols et du gleysol dans un bassin hydrographique; (ii) caractériser substanceshumiques et comprendre les schémas de distribution des acides fulviens et humiques dans une séquence desol podzols le long des profils et dans les horizons du sols en tenant compte des caractéristiquesmorphologiques, de la texture, du pH, carbone variation totale et souterraine dans les horizons des solsd'une séquence de sols podzols; (iii) étudier la capacité de complexation des substances humiques (acidesfulviques et humiques) des échantillons de sol de podzols dans le bassin du Alto Rio Negro, en identifiantles composants fluorescents des substances humiques, en évaluant les capacités et les constantescomplexantes de ces substances avec les métaux Cu+ 2 et Al+ 3 et la comparaison avec les groupesfonctionnels avec la fluorescence infrarouge à transformée de Fourier (FTIR). Encore les acides fulviquessoient plus aromatiques et condensés, leur caractère est principalement aliphatique et hydrophile etsecondairement aromatique et carboxylique. Les acides humiques sont moins aromatiques et moinscondensés que les acides fulviques et sont caractérisés par des fonctions polysaccharide et éther/alcool,mais secondairement leur caractère est aliphatique et hydrophile. Ces différences sont associées à laprésence des groupes fonctionnels qui répondent aux différences dans la dynamique de complexation desmétaux, dans les complexes acide humique, la complexation des métaux Cu+ 2 et Al+ 3 est associée auxfonctions ether/alcool et CO, polysaccharides pendant la période acide fulvic la corrélation est la plus élevéeavec les groupes fonctionnels -CH, -OH et COOH carboxylique.
2017_Rossin_Bruna_Gomes.pdf (2.52 Mo) Télécharger le fichier
tel-02530312 , version 1 (02-04-2020)
  • HAL Id : tel-02530312 , version 1
Bruna Gomes Rossin. Estudo das substâncias húmicas em pedo-paisagem podzolizada na bacia do Alto Rio Negro- AM, Brasil. Analytical chemistry. Université de Toulon; Universidade de São Paulo (Brésil), 2017. Portuguese. ⟨NNT : 2017TOUL0022⟩. ⟨tel-02530312⟩
124 Consultations
127 Téléchargements
