CSIFT : A SIFT Descriptor with Color Invariant Characteristics, vol.2, 2006. ,
FREAK : Fast Retina Keypoint, IEEE Conference on Computer Vision and Pattern Recognition, pp.510-517, 2012. ,
, , pp.214-227, 2012.
Fast explicit diffusion for accelerated features in nonlinear scale spaces, Proceedings of the British Machine Vision Conference, 2013. ,
Simultaneous Algebraic Reconstruction Technique (SART) : A superior implementation of the ART algorithm, Ultrasonic Imaging, vol.6, issue.1, pp.81-94, 1984. ,
DART : A Practical Reconstruction Algorithm for Discrete Tomography, IEEE Trans. Image Process, vol.20, issue.9, pp.2542-2553, 2011. ,
Speeded-Up Robust Features (SURF), Comput. Vision Image Understanding, vol.110, issue.3, pp.346-359, 2008. ,
Development of a fast electromagnetic beam blanker for compressed sensing in scanning transmission electron microscopy, Appl. Phys. Lett, vol.108, issue.9, p.93103, 2016. ,
Shape indexing using approximate nearest-neighbour search in highdimensional spaces, IEEE, 1997. ,
Trace : a high-throughput tomographic reconstruction engine for large-scale datasets, Adv. Struct. Chem. Imag, vol.3, issue.1, pp.1-10, 2017. ,
The OpenCV Library. Dr. Dobb's Journal of Software Tools, 2000. ,
Recognising panoramas. IEEE, 2003. ,
Automatic Panoramic Image Stitching using Invariant Features, Int. J. Comput. Vision, vol.74, issue.1, pp.59-73, 2007. ,
High-resolution low-dose scanning transmission electron microscopy, J. Electron Microsc, vol.59, issue.2, pp.103-112, 2009. ,
Cahn-Hilliard Inpainting and a Generalization for Grayvalue Images, SIAM J. Imag. Sci, vol.2, issue.4, pp.1129-1167, 2009. ,
Stable signal recovery from incomplete and inaccurate measurements, Commun. Pure Appl. Math, vol.59, issue.8, pp.1207-1223, 2006. ,
A GPU powered software package for robust fiducial-less alignment of cryo tilt-series, J. Struct. Biol, vol.170, issue.1, pp.117-126, 2010. ,
Variational image inpainting, Commun. Pure Appl. Math, vol.58, issue.5, pp.579-619, 2005. ,
Batenburg Kees Joost, de With Gijsbertus, and Friedrich Heiner. The properties of SIRT, TVM, and DART for 3D imaging of tubular domains in nanocomposite thin-films and sections, Ultramicroscopy, vol.147, pp.137-148, 2014. ,
Electron Energy Loss Spectroscopy imaging of surface plasmons at the nanometer scale, Ultramicroscopy, vol.162, pp.1-24, 2016. ,
A scanning microscope with 5 Å resolution, J. Mol. Biol, vol.48, issue.3, pp.375-393, 1970. ,
Overview of chemical imaging methods to address biological questions, Micron, vol.84, pp.23-36, 2016. ,
Transmission electron microscopy with Zernike phase plate, Ultramicroscopy, vol.88, issue.4, pp.243-252, 2001. ,
Optimizing the phase shift and the cut-on periodicity of phase plates for TEM, Ultramicroscopy, vol.111, issue.8, pp.1305-1315, 2011. ,
Practical factors affecting the performance of a thin-film phase plate for transmission electron microscopy, Ultramicroscopy, vol.109, issue.4, pp.312-325, 2009. ,
Volta potential phase plate for in-focus phase contrast transmission electron microscopy, Proc. Natl. Acad. Sci. U.S.A, vol.111, issue.44, pp.15635-15640, 2014. ,
Seeing structures and measuring properties with transmission electron microscopy images : A simple combination to study size effects in nanoparticle systems, Appl. Phys. Lett, vol.94, issue.26, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00413874
Compressed sensing, IEEE Transactions on Information Theory, vol.52, 2006. ,
URL : https://hal.archives-ouvertes.fr/inria-00369486
, J. Phys. Colloques, vol.45, issue.C7, 1984.
Cryo-electron microscopy of vitrified specimens, Q. Rev. Biophys, vol.21, issue.2, pp.129-228, 1988. ,
Characterisation of ferromagnetic rings for Zernike phase plates using the Aharonov-Bohm effect, Ultramicroscopy, vol.120, pp.78-85, 2012. ,
Radiation damage in the TEM and SEM, Micron, vol.35, issue.6, pp.399-409, 2004. ,
Random sample consensus : a paradigm for model fitting with applications to image analysis and automated cartography, Commun. ACM, vol.24, issue.6, pp.381-395, 1981. ,
Gerthsen Dagmar, and Schröder Rasmus R. In-Focus Electrostatic Zach Phase Plate Imaging for Transmission Electron Microscopy with Tunable Phase Contrast of Frozen Hydrated Biological Samples, Microsc. Microanal, vol.20, issue.1, pp.175-183, 2014. ,
Robust smoothing of gridded data in one and higher dimensions with missing values, Computational Statistics & Data Analysis, vol.54, issue.4, pp.1167-1178, 2010. ,
Iterative methods for the three-dimensional reconstruction of an object from projections, J. Theor. Biol, vol.36, issue.1, pp.105-117, 1972. ,
What and Where : 3D Object Recognition with Accurate Pose. SpringerLink, pp.67-82, 2006. ,
Algebraic Reconstruction Techniques (ART) for three-dimensional electron microscopy and X-ray photography, J. Theor. Biol, vol.29, issue.3, pp.471-481, 1970. ,
, Compressed Sensing Electron Tomography for Determining Biological Structure. Sci. Rep, vol.6, p.27614, 2016.
A markerfree automatic alignment method based on scale-invariant features, J. Struct. Biol, vol.186, issue.1, pp.167-180, 2014. ,
Cellular Imaging, 2018. ,
Axoneme Structure from Motile Cilia, Cold Spring Harbor Perspect. Biol, vol.9, issue.1, p.28076, 2017. ,
, Comparative Evaluation of Well-known Feature Detectors and Descriptors. International Journal of Applied Mathematics Electronics and Computers, vol.3, issue.1, pp.1-6, 2015.
, Measuring probe convergent angle in stem mode and take off angle in haadf, JEOL, 2003.
GPU implementation of cross-correlation for image generation in real time, 9th International Conference on Signal Processing and Communication Systems (ICSPCS), pp.1-6, 2015. ,
PCA-SIFT : a more distinctive representation for local image descriptors, vol.2, 2004. ,
Cryo-electron microscopy single particle reconstruction of virus particles using compressed sensing theory, Computational Imaging V, vol.6498, p.64981, 2007. ,
Towards full-resolution inline electron holography, Micron, vol.63, pp.69-75, 2014. ,
Designer Extraordinaire of the Electron Microscope : A Memoir, Advances in Imaging and Electron Physics, vol.95, pp.2-62, 1906. ,
Local Descriptors for Spatio-temporal Recognition. SpringerLink, pp.91-103, 2004. ,
Compressed sensing electron tomography, Ultramicroscopy, vol.131, pp.70-91, 2013. ,
, Binary Robust invariant scalable keypoints. 2011 International Conference on Computer Vision, pp.2548-2555, 2011.
GSIFT : geometric scale invariant feature transform for terrain data, Vision Geometry XIV, vol.6066, p.60660, 2006. ,
Distinctive Image Features from Scale-Invariant Keypoints, Int. J. Comput. Vision, vol.60, issue.2, pp.91-110, 2004. ,
Practical Experience with Hole-Free Phase Plates for Cryo Electron Microscopy, Microsc. Microanal, vol.22, issue.6, pp.1316-1328, 2014. ,
, Fiducial Marker and Hybrid Alignment Methods for Single-and Doubleaxis Tomography. SpringerLink, pp.163-185, 2007.
Robust wide-baseline stereo from maximally stable extremal regions, Image Vision Comput, vol.22, issue.10, pp.761-767, 2004. ,
The phase constancy of electron waves traveling through Boersch's electrostatic phase plate, Ultramicroscopy, vol.63, issue.1, pp.5-10, 1996. ,
TomoJ : tomography software for three-dimensional reconstruction in transmission electron microscopy, BMC Bioinf, vol.8, issue.1, pp.1-9, 2007. ,
Three-Dimensional Chemical Mapping by EFTEM-TomoJ Including Improvement of SNR by PCA and ART Reconstruction of Volume by Noise Suppression. Microsc. Microanal, vol.19, pp.1669-1677, 2013. ,
3D electron microscopy in the physical sciences : the development of Z-contrast and EFTEM tomography, Ultramicroscopy, vol.96, issue.3, pp.413-431, 2003. ,
Nanoscale scanning transmission electron tomography, J. Microsc, vol.223, issue.3, pp.185-190, 2006. ,
ASIFT : A New Framework for Fully Affine Invariant Image Comparison, SIAM J. Imag. Sci, vol.2, issue.2, pp.438-469, 2009. ,
Phase contrast electron microscopy : development of thin-film phase plates and biological applications, Philosophical Transactions of the Royal Society B : Biological Sciences, 2008. ,
Basal body assembly in ciliates : the power of numbers, Traffic, vol.10, issue.5, p.461, 2009. ,
Scanning Transmission Electron Microscopy | Springer-Link, 2011. ,
On the determination of functions from their integral values along certain manifolds, IEEE Trans. Med. Imaging, vol.5, issue.4, pp.170-176, 1986. ,
Transmission Electron Microscopy -Physics of Image Formation | Ludwig Reimer | Springer, 2008. ,
Machine Learning for High-Speed Corner Detection. Sprin-gerLink, pp.430-443, 2006. ,
ORB : An efficient alternative to SIFT or SURF, International Conference on Computer Vision, pp.2564-2571, 2011. ,
A 3-dimensional sift descriptor and its application to action recognition, 2007. ,
Vision-based mobile robot localization and mapping using scaleinvariant features, vol.2, 2001. ,
Communication in the Presence of Noise, Proc. IRE, vol.37, pp.10-21, 1949. ,
Marker-free image registration of electron tomography tiltseries, BMC Bioinf, vol.10, issue.1, p.124, 2009. ,
Monte Carlo electrontrajectory simulations in bright-field and dark-field STEM : Implications for tomography of thick biological sections, Ultramicroscopy, vol.109, issue.3, pp.213-221, 2009. ,
, Biomedical Image Processing. Computer, vol.16, issue.1, pp.22-34, 1983.
A comparative study on the application of SIFT, SURF, BRIEF and ORB for 3D surface reconstruction of electron microscopy images, Computer Methods in Biomechanics and Biomedical Engineering : Imaging & Visualization, vol.6, issue.1, pp.17-30, 2018. ,
, International Conference on Computing, Mathematics and Engineering Technologies (iCo-MET), pp.1-10, 2018.
, Paramecium tetraurelia basal body structure. Cilia, vol.5, pp.1-6, 2015.
Solution of Incorrectly Formulated Problems and the Regularization Method, 1963. ,
STEM tomography analysis of the trypanosome transition zone, J. Struct. Biol, vol.202, issue.1, pp.51-60, 2018. ,
, Alignment of Tilt Series. SpringerLink, pp.183-207, 2018.
An ImageJ tool for simplified post-treatment of TEM phase contrast images (SPCI), vol.121, pp.90-98, 2019. ,
, Z. Angew. Phys, vol.109, issue.9, pp.553-572, 1938.
Ordered-subset simultaneous algebraic reconstruction techniques (OS-SART), J. X-Ray Sci. Technol, vol.12, issue.3, pp.169-177, 2004. ,
Transmission Electron Microscopy -A Textbook for Materials Science, 2009. ,
Accurate marker-free alignment with simultaneous geometry determination and reconstruction of tilt series in electron tomography, Ultramicroscopy, vol.106, issue.3, pp.240-254, 2006. ,
Cryo-scanning transmission electron tomography of vitrified cells, Nat. Methods, vol.11, issue.4, p.423, 2014. ,
A Comparative Study of SIFT and its Variants, Measurement Science Review, vol.13, issue.3, pp.122-131, 2013. ,
Phase contrast, a new method for the microscopic observation of transparent objects, Physica, vol.9, issue.7, pp.686-698, 1942. ,
Image zooming using directional cubic convolution interpolation, IET Image Proc, vol.6, issue.6, pp.627-634, 2012. ,
, KAZE Features. SpringerLink, 2012.
Markov random field based automatic image alignment for electron tomography, J. Struct. Biol, vol.161, pp.260-275, 2008. ,
, , 2015.
Speeded-Up Robust Features (SURF). Comput. Vision Image Understanding 110, pp.346-359, 2008. ,
Shape indexing using approximate nearest-neighbour search in high-dimensional spaces, IEEE, 1997. ,
Automatic Alignment of Transmission Electron Microscope Tilt Series without Fiducial Markers, J. Struct. Biol, vol.136, pp.201-213, 2001. ,
A fully automatic alignment of electron tomography images without fiducial markers, Proceedings of the IAPR Conference on Machine Vision Applications (IAPR MVA 2000), pp.307-310, 2000. ,
Flagellum Structure and Function in Trypanosomes, pp.63-86, 2010. ,
BRIEF: Binary Robust Independent Elementary Features. SpringerLink, 2010. ,
Conserved structural motifs in the central pair complex of eukaryotic flagella, Cytoskeleton, vol.70, pp.101-120, 2013. ,
Alignator: A GPU powered software package for robust fiducial-less alignment of cryo tilt-series, J. Struct. Biol, vol.170, pp.117-126, 2010. ,
A marker-free automatic alignment method based on scale-invariant features, J. Struct. Biol, vol.186, pp.167-180, 2014. ,
A new scale invariant feature detector and modified SURF descriptor, Sixth International Conference on Natural Computation, vol.7, pp.3734-3738, 2010. ,
Structure of the membrane-assembled retromer coat determined by cryo-electron tomography, Nature, vol.561, pp.561-564, 2018. ,
Structure of Trypanosoma brucei flagellum accounts for its bihelical motion, Proc. Natl. Acad. Sci. U.S.A, vol.108, pp.11105-11108, 2011. ,
BRISK: Binary Robust invariant scalable keypoints, International Conference on Computer Vision, 2011. ,
Distinctive Image Features from Scale-Invariant Keypoints, Int. J. Comput. Vision, vol.60, pp.91-110, 2004. ,
Adaptive and Generic Corner Detection Based on the Accelerated Segment Test. SpringerLink, p.183, 2010. ,
Fiducial Marker and Hybrid Alignment Methods for Single-and Double-axis Tomography. SpringerLink, 2007. ,
Automated tilt series alignment and tomographic reconstruction in IMOD, J. Struct. Biol, vol.197, pp.102-113, 2017. ,
High-resolution structures of HIV-1 Gag cleavage mutants determine structural switch for virus maturation, Proc. Natl. Acad. Sci. U.S.A, vol.115, 2018. ,
Online; accessed 27, 2011. ,
TomoJ: tomography software for threedimensional reconstruction in transmission electron microscopy, BMC Bioinf, vol.8, p.288, 2007. ,
Evaluation of local detectors and descriptors for fast feature matching, Proceedings of the 21st International Conference on Pattern Recognition (ICPR2012), pp.2681-2684, 2012. ,
Orientation of the central pair complex during flagellar bend formation in Chlamydomonas, Cell Motil. Cytoskeleton, vol.56, pp.120-129, 2003. ,
Chapter 13 -Analysis of the Central Pair Microtubule Complex in Chlamydomonas reinhardtii, Methods in Cell Biology, vol.92, pp.92013-92019, 2009. ,
Machine Learning for High-Speed Corner Detection. SpringerLink, p.430, 2006. ,
ORB: An efficient alternative to SIFT or SURF, International Conference on Computer Vision, 2011. ,
Three-dimensional reconstruction of imperfect twodimensional crystals, Ultramicroscopy, vol.13, pp.57-70, 1984. ,
Ultrastructural evaluation of shrinkage artefacts induced by fixatives and embedding resins on osteocyte processes and pericellular space dimensions, J. Biomed. Mater. Res. Part A, vol.103, pp.1565-1576, 2015. ,
Marker-free image registration of electron tomography tilt-series, BMC Bioinf, vol.10, p.124, 2009. ,
STEM tomography analysis of the trypanosome transition zone, J. Struct. Biol, vol.202, pp.51-60, 2018. ,
Ordered-subset simultaneous algebraic reconstruction techniques (OS-SART), 2004. ,
Seeing structures and measuring properties with transmission electron microscopy images: a simple combination to study size effects in nanoparticle systems, Appl. Phys. Lett, vol.12, p.000267697300053, 2008. ,
Phase measurement of atomic resolution image using transport of intensity equation, J. Electron Microsc, vol.54, pp.191-197, 2005. ,
Radiation damage in single-particle cryo-electron microscopy: effects of dose and dose rate, J. Synchrotron Radiat, vol.18, 2011. ,
The Attachment of the Bacterial Chromosome to the Cell Membrane, Int. Rev. Cytol, vol.41, issue.08, p.60964, 1975. ,
Projected thickness reconstruction from a single defocused transmission electron microscope image of an amorphous object, Ultramicroscopy, vol.111, pp.959-968, 2011. ,
TomoJ: tomography software for three-dimensional reconstruction in transmission electron microscopy, BMC Bioinform, vol.8, 2007. ,
, , 2011.
Quantitativeness of phase measurement by transport of intensity equation, J. Electron Microsc, vol.59, pp.33-41, 2010. ,
, Micron, vol.121, pp.90-98, 2019.
Sub-?ngstrom high-resolution transmission electron microscopy at 300 keV, Ultramicroscopy, vol.89, pp.215-241, 2001. ,
Noninterferometric phase imaging with partially coherent light, Phys. Rev. Lett, vol.80, pp.2586-2589, 1998. ,
Simultaneous phase and amplitude extraction from a single defocused image of a homogeneous object, J. Microsc, vol.206, pp.33-40, 2002. ,
Increase of the mean inner Coulomb potential in Au clusters induced by surface tension and its implication for electron scattering, Phys. Rev. B, vol.76, p.235411, 2007. ,
Transmission Electron Microscopy -Physics of Image Formation and Microanalysis, 1989. ,
Image reconstruction by means of focus series, J. Microsc, vol.207, 2002. ,
NIH image to ImageJ: 25 years of image analysis, Nat. Methods, vol.9, p.671, 2012. ,
A pyramid approach to subpixel registration based on intensity, IEEE Trans. Image Process, vol.7, pp.27-41, 1998. ,
Computational Color Imaging, 2009. ,
URL: https:// sites.google.com/site/qingzongtseng/template-matching-ij-plugin (Online; accessed 27, ImageJ Plugins, vol.11, 2018. ,
Sub-ångström structure characterisation: the Brite-Euram route towards one ångström, Ultramicroscopy, vol.64, pp.1-15, 1996. ,
SPCI Plugin Distribution, 2018. ,
Parallel colt: a high-performance Java library for scientific computing and image processing, ACM Trans. Math. Software, vol.37, pp.1-22, 2010. ,
