Epigenetic function of the amino-terminal domain of CENP-A during mitosis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Etude des fonctions du domaine amino-terminal de CENP-A pendant la mitose
The histone variant CENP-A epigenetically marks the centromere. The presence of CENP-A at the centromeres allows the recruitment of centromeric proteins that constitute the platform for functional kinetochores.In human cells, the NH2-terminus of CENP-A and its phosphorylation at serine 7 in mitosis has been reported to be crucial for the progression of mitosis. However, no phosphorylation of CENP-A in other metazoan species has been described. Here, we show that the NH2-terminus of CENP-A, but not its primary sequence, is required for mitosis in mouse embryonic cells (MEFs). Our data show that the mitotic defects resulting from the depletion of the endogenous CENP-A can be rescued when MEFs expressing a GFP- CENP-A mutant where the NH2-terminus of CENP-A was swapped with the phosphorylatable tail of conventional histone H3. Conversely, no rescue was observed when the two phosphorylatable serines in the H3 tail mutant were replaced with alanines. Furthermore, a non-phosphorylatable fusion mutant of CENP-A where all seven serines in the amino-tail were replaced with alanines, was also unable to rescue the mitotic phenotype of CENP-A depleted cells.We also identified that the first three serines of the tail of CENP-A as potential sites for phosphorylation. Additionally, we were able to link the phosphorylation of CENP-A amino-tail to the proper localization of the key centromeric protein CENP-C. These results suggest that mitotic CENP-A phosphorylation is a potentially common event in metazoans essential for mitotic progression.In the second par of this work we wanted to unambiguously tie the NH2-terminus function of CENP-A to mitosis. To achieve this, we wanted to remove the CENP-A amino-tail only during mitosis and we devised a new method called the Hara-kiri approach in order to answer the above question in human cells. The removal of the NH2-terminal domain of CENP-A using the Hara-kiri approach at the onset of mitosis led to increased mitotic defects in cells. Taken collectively these data show that the CENP-A NH2- terminus is required during mitosis to assure proper cell division.
Le variant d’histone CENP-A marque épigénétiquement le centromère. La présence de CENP-A au centromère permet le recrutement de protéines centromériques qui constituent la plateforme pour l’assemblage de kinétochores fonctionnels.Dans les cellules humaines, l'extrémité amino-terminale de CENP-A ainsi que la phosphorylation de la sérine 7, ont été signalées comme étant cruciales pour la progression de la mitose. Cependant, aucune phosphorylation de CENP-A dans d'autres espèces de métazoaires n'a été décrite. Ici, nous montrons que le domaine NH2-terminal CENP-A, mais pas sa séquence primaire, est nécessaire pour la mitose dans les fibroblastes embryonnaires de souris (MEFs). Nos données montrent que les défauts mitotiques résultant de la déplétion de CENP-A endogène peuvent être restaurés lorsque les MEFs expriment un mutant GFP-CENP-A dont l'extrémité NH2-terminal de CENP-A a été échangée par la queue phosphorylable de l'histone canonique H3. Inversement, dans ce même mutant, lorsque l’on remplace les deux serines phosphorylables par des résidus alanines, les défauts mitotiques persistent. En outre, le mutant de fusion non- phosphorylable de CENP-A, où les sept serines du domaine NH2-terminal ont été remplacées par des résidus alanines, a été également incapable de restaurer le phénotype mitotique des cellules déplétées en CENP-A endogène.Nous avons également identifié les trois premières sérines de la queue de CENP-A comme sites potentiels de phosphorylation. De plus, nos résultats montrent que l’absence de phosphorylation du domaine amino-terminal conduit à la délocalisation de la protéine centromérique CENP-C. Ces résultats suggèrent que la phosphorylation mitotique de CENP-A est un événement potentiellement fréquent chez les métazoaires et essentiel à la progression mitotique.Dans la seconde partie de ce travail, nous avons voulu lier sans ambiguïté la fonction du domaine NH2-terminal du CENP-A à la mitose. Nous avons conçu une nouvelle méthode, appelée approche Hara-kiri, pour pouvoir éliminer le domaine NH2- terminal seulement pendant la mitose. Ceci afin de répondre à la question ci-dessus dans les cellules humaines. L'élimination du domaine NH2-terminal du CENP-A en utilisant l'approche Hara-kiri en début de mitose a conduit à une augmentation des défauts mitotiques dans les cellules. Prises collectivement, ces données montrent que le domaine NH2-terminal CENP-A est nécessaire pendant la mitose afin d’assurer le bon déroulement de la division cellulaire.
DALKARA_2017_archivage.pdf (2.82 Mo) Télécharger le fichier
tel-02910197 , version 1 (01-08-2020)
  • HAL Id : tel-02910197 , version 1
Defne Dalkara. Epigenetic function of the amino-terminal domain of CENP-A during mitosis. Cellular Biology. Université Grenoble Alpes, 2017. English. ⟨NNT : 2017GREAV001⟩. ⟨tel-02910197⟩
210 Consultations
161 Téléchargements
