Irréalisme et incorporation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2019
Unrealism and incorporation
This philosophical work is about the logic of incorporation (Einverleibung) related to the esthetic. The main thesis of this study is the following one  : the aesthetic is above the ontology, the aesthetic logic of the body is above the logic of the be. The main purpose of this work is thus to unfold the concept of incorporation and to link it with the concepts of «  decorporation  » and «  recorporation  », and with the stoic concept of krasis which means the blend or mixing of the bodies. The first hypothesis is that this is not the body which incorporates, but that the body is «  generated  » by an incorporation-process. But how can we describe the incorporation if this is not a phenomenon, but a process which passes through phenomenality itself  ? How can we describe the genesis of the sensibility and the sensitivity? These questions require an aesthetic heuristic between the enquiry (Hume) and the genealogy (Nietzsche). We have also to distinguish incorporation, incarnation (embodiment) and organism, to show that flesh and organs are incorporated. This involves a specific thesis about Kant's schematism  : the transcendental is generated by the incorporation of schemes.This works has two parts  : the first is about the incorporation and the aesthetic as logic of experience. The second one is about the stoic comprehension of incorporation.
Ce travail de philosophie porte sur la logique de l'incorporation (Einverleibung) dans son rapport à l'esthétique. La thèse principale est la suivante : la précédence en droit de l'esthétique quant à l'ontologie. Il s'agit de déployer le concept d'incorporation en le liant aux concepts de «  décorporation  » et de «  récorporation  » ainsi qu'à la notion stoïcienne de crase ou krasis. L'axe directeur est le suivant : ce n'est pas le corps constitué qui incorpore, c'est le corps qui est le produit métastable d'un processus d'incorporation. Mais comment aborder l'incorporation si elle n'est pas phénoménale, traverse la phénoménalité sans s'y exhausser  ? Comment décrire la genèse du sensible dans le corps (percevoir, sentir)  ? Ces questions impliquent un concept d'heuristique lié à la notion humienne d'enquête et au concept nietzschéen de généalogie. Elles nécessitent ensuite de différencier le concept d'incorporation de ceux d'incarnation et d'organisme, en montrant comment l'organicité et la chair sont a priori incorporées, mais subsument en retour ce processus d'incorporation. Cela engage enfin une thèse sur le schématisme kantien : ce n'est pas le transcendantal qui est articulé par le schématisme, mais que ce sont les schèmes incorporés et le schématisme les régissant qui vont constituer la base sur laquelle le transcendantal va s'édifier. L'ensemble se compose de deux parties  : la première porte sur le rapport de l'incorporation et de l'esthétique entendue comme logique de l'expérience, la seconde sur le concept d'incorporation dans son acception stoïcienne et sur le schématisme.
Bellier_Aurelien.pdf (4.03 Mo) Télécharger le fichier
tel-02940603 , version 1 (16-09-2020)
  • HAL Id : tel-02940603 , version 1
Aurelien Bellier. Irréalisme et incorporation. Philosophie. Université Toulouse le Mirail - Toulouse II, 2019. Français. ⟨NNT : 2019TOU20069⟩. ⟨tel-02940603⟩
282 Consultations
321 Téléchargements
