Theses
Embedded and high-order meshes : two alternatives to linear body-fitted meshes
Abstract : The numerical simulation of complex physical phenomena usually requires a mesh. In Computational Fluid Dynamics, it consists in representing an object inside a huge control volume. This object is then the subject of some physical study. In general, this object and its bounding box are represented by linear surface meshes and the intermediary zone is filled by a volume mesh. The aim of this thesis is to have a look at two different approaches for representing the object. The first approach, called embedded method, consists in fully meshing the bounding box volume without explicitly meshing the object in it. In this case, the presence of the object is implicitly simulated by the CFD solver. The coupling of this method with linear mesh adaptation is in particular discussed. The second approach, called high-order method, consists on the contrary in increasing the polynomial order of the surface mesh of the object. The first step is therefore to generate a suitable high-order surface mesh and then to propagate the high-order information in the neighboring volume if necessary. In this context, it is mandatory to make sure that such modifications are valid and to consider the extension of classic linear mesh modification techniques. Also, a special care has to be done on the development of new mesh and solution visualization methods as the classic ones fail to properly render this new type of entities.
Complete list of metadata
Cited literature [225 references]  Display  Hide  Download
https://hal.inria.fr/tel-02950311
Contributor : Rémi Feuillet Connect in order to contact the contributor
Submitted on : Sunday, September 27, 2020 - 5:59:55 PM
Last modification on : Friday, April 30, 2021 - 9:55:17 AM
Identifiers
  • HAL Id : tel-02950311, version 1
Citation
Rémi Feuillet. Embedded and high-order meshes : two alternatives to linear body-fitted meshes. Numerical Analysis [math.NA]. Université Paris-Saclay, 2019. English. ⟨tel-02950311⟩
Share
Metrics
Record views
52
Files downloads
664
