Efficient and Privacy-Preserving Compressive Learning
Méthodes efficaces pour l'apprentissage compressif avec garanties de confidentialité
The topic of this Ph.D. thesis lies on the borderline between signal processing, statistics and computer science. It mainly focuses on compressive learning, a paradigm for large-scale machine learning in which the whole dataset is compressed down to a single vector of randomized generalized moments, called the sketch. An approximate solution of the learning task at hand is then estimated from this sketch, without using the initial data. This framework is by nature suited for learning from distributed collections or data streams, and has already been instantiated with success on several unsupervised learning tasks such as k-means clustering, density fitting using Gaussian mixture models, or principal component analysis.
We improve this framework in multiple directions. First, it is shown that perturbing the sketch with additive noise is sufficient to derive (differential) privacy guarantees. Sharp bounds on the noise level required to obtain a given privacy level are provided, and the proposed method is shown empirically to compare favorably with state-of-the-art techniques. Then, the compression scheme is modified to leverage structured random matrices, which reduce the computational cost of the framework and make it possible to learn on high-dimensional data. Lastly, we introduce a new algorithm based on message passing techniques to learn from the sketch for the k-means clustering problem. These contributions open the way for a broader application of the framework.
Ce travail de thèse, qui se situe à l'interface entre traitement du signal, informatique et statistiques, vise à l'élaboration de méthodes d'apprentissage automatique à grande échelle et de garanties théoriques associées. Il s'intéresse en particulier à l'apprentissage compressif, un paradigme dans lequel le jeu de données est compressé en un unique vecteur de moments généralisés aléatoires, appelé le sketch et contenant l'information nécessaire pour résoudre de manière approchée la tâche d'apprentissage considérée. Le schéma de compression utilisé permet de tirer profit d'une architecture distribuée ou de traiter des données en flux, et a déjà été utilisé avec succès sur plusieurs tâches d'apprentissage non-supervisé : partitionnement type k-moyennes, modélisation de densité avec modèle de mélange gaussien, analyse en composantes principales.
Les contributions de la thèse s'intègrent dans ce cadre de plusieurs manières. D'une part, il est montré qu'en bruitant le sketch, des garanties de confidentialité (différentielle) peuvent être obtenues; des bornes exactes sur le niveau de bruit requis sont données, et une comparaison expérimentale permet d'établir que l'approche proposée est compétitive vis-à-vis d'autres méthodes récentes. Ensuite, le schéma de compression est adapté pour utiliser des matrices aléatoires structurées, qui permettent de réduire significativement les coûts de calcul et rendent possible l'utilisation de méthodes compressives sur des données de grande dimension. Enfin, un nouvel algorithme basé sur la propagation de convictions est proposé pour résoudre la phase d'apprentissage (à partir du sketch) pour le problème de partitionnement type k-moyennes.
