Degradable Polymer Prodrugs by Nitroxide-Mediated Radical Ring-Opening Polymerization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Prodrogues Polymères Dégradables par Polymérisation Radicalaire par Ouverture de Cycle Contrôlée par les Nitroxydes
Nitroxide-mediated radical ring-opening copolymerization of methacrylic esters and cyclic ketene acetals was investigated and enabled the synthesis of well-defined degradable vinyl copolymers containing ester groups along the main chain, whose amount was readily adjusted by changing the initial comonomer feed. More specifically, the copolymerizations of 2-methylene-4-phenyl-1,3-dioxolane (MPDL) and either oligo(ethylene glycol) methyl ether methacrylate (OEGMA) or methyl methacrylate (MMA) were initiated by an alkoxyamine initiator based on the SG1 nitroxide. It led to a library of P(OEGMA-co-MPDL) and P(MMA-co-MPDL) materials that were hydrolytically degraded under both accelerated and physiological conditions. Their hydrolytic degradation kinetics were also benchmarked against traditional polyesters (e.g., PLGA, PLA and PCL) where P(OEGMA-co-MPDL) copolymers showed tunable degradation rates as function of the MPDL content, being in between those of PLA and PCL. Conversely, the more hydrophobic P(MMA-co-MPDL) copolymers exhibited much slower hydrolysis than that of PCL. In a second step, a new class of degradable polymer prodrugs was developed by nitroxide-mediated radical ring-opening copolymerization of MPDL with OEGMA or MMA, from a drug-bearing initiator (‘drug-initiated’ method). To do so, Gemcitabine, an anticancer drug, was derivatized with a SG1-based alkoxyamine to initiate the copolymerization reaction. The resulting degradable polymer prodrugs exhibited interesting characteristics in terms of drug release and in vitro cytotoxicity, depending on the nature of the methacrylic ester used, the nature of the linker between the drug and the polymer and the MPDL content. This study enabled us to extract important structure-activity relationships of great importance for further development.
La copolymérisation radicalaire par ouverture de cycle contrôlée par les nitroxydes entre les esters méthacryliques et les acétals de cétène cycliques a permis de synthétiser des copolymères vinyliques bien contrôlés et dégradables contenant des fonctions esters le long de la chaine polymère. Plus précisément, des copolymérisations entre le 2-méthylène-4-phenyl-1,3-dioxolane (MPDL) et l’oligo(éthylène glycol) méthyl éther méthacrylate (OEGMA) ou le méthacrylate de méthyle (MMA) ont été amorcées par une alkoxyamine basée sur le nitroxyde SG1. Des copolymères de type P(OEGMA-co-MPDL) et P(MMA-co-MPDL) ont été obtenus et dégradés hydrolytiquement en conditions accélérées ou physiologiques. Leurs cinétiques de dégradation furent également comparées à celles de polyesters traditionnels (e.g., PLGA, PLA and PCL) où il a été montré que la dégradation des copolymères de P(OEGMA-co-MPDL) pouvait être ajustée par la stœchiométrie initiale en monomères et qu’elle se situait entre celles du PLA et du PCL. En revanche, les copolymères de P(MMA-co-MPDL), plus hydrophobes, ont présenté une hydrolyse très lente, bien inférieure à celle du PCL. Dans un deuxième temps, une nouvelle famille de prodrogues polymères dégradable a été synthétisé par copolymérisation radicalaire par ouverture de cycle contrôlée par les nitroxydes entre le MPDL et l’OEGMA ou le MMA, à partir d’un amorceur couplé à un principe actif (méthode du principe actif amorceur). Pour ce faire, la Gemcitabine, un principe actif anticancéreux, a été couplé à une alcoxyamine à base SG1 qui fut ensuite utilisée pour amorcer la réaction de copolymérisation. Les copolymères ainsi obtenus ont montré des propriétés de libération de la Gem et des activités cytotoxiques sur différentes lignées cellulaires en relation avec la nature de l’ester méthacrylique utilisé, la nature de la liaison entre la Gem et le copolymère ainsi que le taux de MPDL dans le copolymère. Cette étude nous a permis d’extraire des relations de type structure-activité importantes pour des développements futurs.
71549_GUEGAIN_2017_archivage.pdf (16.74 Mo) Télécharger le fichier
tel-03029790 , version 1 (29-11-2020)
  • HAL Id : tel-03029790 , version 1
Elise Guegain. Degradable Polymer Prodrugs by Nitroxide-Mediated Radical Ring-Opening Polymerization. Polymers. Université Paris Saclay (COmUE), 2017. English. ⟨NNT : 2017SACLS569⟩. ⟨tel-03029790⟩
214 Consultations
36 Téléchargements
