Development and verification of arbitrary-precision integer arithmetic libraries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2020
Développement et vérification de bibliothèques d'arithmétique entière en précision arbitraire
Arbitrary-precision integer arithmetic algorithms are used in contexts where both their performance and their correctness are critical, such as cryptographic software or computer algebra systems. GMP is a very widely-used arbitrary-precision integer arithmetic library. It features state-of-the-art algorithms that are intricate enough that their formal verification is both justified and difficult. This thesis tackles the formal verification of the functional correctness of a large fragment of GMP using the Why3 deductive verification platform.In order to make this verification possible, I have made several additions to Why3 that enable the verification of C programs. Why3 features a functional programming and specification language called WhyML. I have developed models of the memory management and datatypes of the C language, allowing me to reimplement GMP's algorithms in WhyML and formally verify them. I have also extended Why3's extraction mechanism so that WhyML programs can be compiled to idiomatic C code, where only OCaml used to be supported.The compilation of my WhyML algorithms results in a verified C library called WhyMP. It implements many state-of-the-art algorithms from GMP, with almost all of the optimization tricks preserved. WhyMP is compatible with GMP and performance-competitive with the assembly-free version. It goes far beyond existing verified arbitrary-precision arithmetic libraries, and is arguably the most ambitious existing Why3 development in terms of size and proof effort.In an attempt to increase the degree of automation of my proofs, I have also added to Why3 a framework for proofs by reflection. It enables Why3 users to easily write dedicated decision procedures that are formally verified programs and make full use of WhyML's imperative features. Using this new framework, I was able to replace hundreds of handwritten proof annotations in my GMP verification by automated proofs.
Les algorithmes d'arithmétique entière en précision arbitraire sont utilisés dans des contextes où leur correction et leurs performances sont critiques, comme les logiciels de cryptographie ou de calcul formel. GMP est une bibliothèque d'arithmétique entière en précision arbitraire très utilisée. Elle propose des algorithmes de pointe, suffisamment complexes pour qu'il soit à la fois justifié et difficile de les vérifier formellement. Cette thèse traite de la vérification formelle de la correction fonctionnelle d'une partie significative de GMP à l'aide de la plateforme de vérification déductive Why3.Afin de rendre cette preuve possible, j'ai fait plusieurs ajouts à Why3 qui permettent la vérification de programmes C. Why3 propose un langage fonctionnel de programmation et de spécification appelé WhyML. J'ai développé des modèles de la gestion de la mémoire et des types du langage C. Ceci m'a permis de réimplanter des algorithmes de GMP en WhyML et de les vérifier formellement. J'ai aussi étendu le mécanisme d'extraction de Why3. Les programmes WhyML peuvent maintenant être compilés vers du C idiomatique, alors que le seul langage cible était OCaml auparavant. La compilation de mes programmes WhyML résulte en une bibliothèque C vérifiée appelée WhyMP. Elle implémente de nombreux algorithmes de pointe tirés de GMP en préservant presque toutes les astuces d'implémentation. WhyMP est compatible avec GMP, et est comparable à la version de GMP sans assembleur écrit à la main en termes de performances. Elle va bien au-delà des bibliothèques d'arithmétique en précision arbitraire vérifiées existantes. C'est sans doute le développement Why3 le plus ambitieux à ce jour en termes de longueur et d'effort de preuve. Afin d'augmenter le degré d'automatisation de mes preuves, j'ai ajouté à Why3 un mécanisme de preuves par réflexion. Il permet aux utilisateurs de Why3 d'écrire des procédures de décision dédiées, formellement vérifiées et qui utilisent pleinement les fonctionnalités impératives de WhyML. À l'aide de ce mécanisme, j'ai pu remplacer des centaines d'annotations manuelles de ma preuve de GMP par des preuves automatiques.
93272_RIEU_2020_archivage.pdf (1.58 Mo) Télécharger le fichier
tel-03032942 , version 1 (01-12-2020)
  • HAL Id : tel-03032942 , version 1
Raphaël Rieu. Development and verification of arbitrary-precision integer arithmetic libraries. Computer Arithmetic. Université Paris-Saclay, 2020. English. ⟨NNT : 2020UPASG023⟩. ⟨tel-03032942⟩
234 Consultations
548 Téléchargements
