Advanced speculation to increase the performance of superscalar processors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2020
Spéculation avancée pour augmenter les performances des processeurs superscalaires
Even in the multicore era, making single cores faster is paramount to achieve high- performance computing, given the existence of programs that are either inherently sequential or expose non-negligible sequential parts. Sequential performance has been essentially improving with the scaling of the processor structures that enable instruction-level parallelism (ILP). However, as modern microarchitectures continue to extract more ILP by employing larger instruction windows, true data dependencies remain a major performance bottleneck. Value Prediction (VP) and Load-Address Prediction (LAP) are two developing techniques that allow to overcome this obstacle and harvest more ILP by enabling the execution of instructions in a data-wise speculative manner. This thesis proposes mechanisms that are related with VP and LAP and lead to effectively higher performance improvements. First, VP is examined in an ISA-aware manner, that discloses the impact of certain ISA particularities on the anticipated speedup. Second, a novel binary-based VP model is introduced, namely VSEP, that allows to exploit certain value patterns that although they are encountered frequently, they cannot be captured by previous works. VSEP improves the obtained speedup by 19% and also, by virtue of its structure, it mitigates the cost of predicting values wider than 64 bits. By adapting this approach to perform LAP allows to predict the memory addresses of 48% of the committed loads. Eventually, a microarchitecture that leverages carefully this LAP mechanism can execute 32% of the committed loads early.
Même à l’ère des multicœurs, il est primordial d’améliorer la performance en contexte monocœur, étant donné l’existence de pro- grammes qui exposent des parties séquentielles non négligeables. Les performances séquentielles se sont essentiellement améliorées avec le passage à l’échelle des structures de processeurs qui permettent le parallélisme d’instructions (ILP). Cependant, les chaînes de dépendances séquentielles li- mitent considérablement la performance. La prédiction de valeurs (VP) et la prédiction d’adresse des lectures mémoire (LAP) sont deux techniques en développement qui permettent de surmonter cet obstacle en permettant l’exécution d’instructions en spéculant sur les données. Cette thèse propose des mécanismes basés sur VP et LAP qui conduisent à des améliorations de performances sensiblement plus élevées. D’abord, VP est examiné au niveau de l’ISA, ce qui fait apparaître l’impact de certaines particularités de l’ISA sur les performances. Ensuite, un nouveau prédicteur binaire (VSEP), qui permet d’exploiter certains motifs de valeurs, qui bien qu’ils soient fréquemment rencontrés, ne sont pas capturés par les modèles précédents, est introduit. VSEP améliore le speedup obtenu de 19% et, grâce à sa structure, il atténue le coût de la prédiction de va- leurs supérieures à 64 bits. Adapter cette approche pour effectuer LAP permet de prédire les adresses de 48% des lectures mémoire. Finalement, une microarchitecture qui exploite soigneusement ce mécanisme de LAP peut exécuter 32% des lectures mémoire en avance.
KALAITZIDIS_Kleovoulos.pdf (2.51 Mo) Télécharger le fichier
tel-03033709 , version 1 (01-12-2020)
  • HAL Id : tel-03033709 , version 1
Kleovoulos Kalaitzidis. Advanced speculation to increase the performance of superscalar processors. Performance [cs.PF]. Université Rennes 1, 2020. English. ⟨NNT : 2020REN1S007⟩. ⟨tel-03033709⟩
338 Consultations
1930 Téléchargements
