Structuration spatiale de la biodiversité agricole dans la zone cotonnière du Mali - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Spatial Structure Of Agricultural Biodiversity In Southern Mali
The diversity of cropping systems and varieties plays an important role in the ability of family farms to withstand socio-economic and environmental shocks. For better conservation, this agricultural diversity needs to be characterized and monitored in space and time. While they were dominated by elements of price, area and production until recently, agricultural monitoring systems are beginning to integrate diversity issues. The diversity of cropping systems and varieties plays an important role in the ability of family farms to resist socio-economic and environmental shocks, whereas until the end of the 1990s it was considered as a limiting factor in improving the productivity of farming systems in varietal selection processes. In a situation of uncertain rainfall, to reduce the risk of this hazard, farmers use several species and varieties to survive and produce through all the hazards encountered. The peasant strategy consists in cultivating several varieties with different agronomic characteristics (early maturity, yield, resistance to diseases, parasites and drought, etc.) and culinary in the same field or in different fields. This strategy allows farmers to cultivate the varieties best suited to the soil conditions of their fields and to meet their diverse needs.It is in this context that this thesis focuses on the spatial structuring of agrobiodiversity in the cotton zone. To achieve this objective, several methods and approaches have been used. The approach adopted combines the digital analysis of satellite imagery and the use of data from field surveys. The analysis of these data is based on the spatial distribution of biodiversity and its correlation with agro-ecological practices and conditions, agronomic performance and performance.The main results from the analysis of the study data are:a) There is a great heterogeneity and diversity of landscapes in the cotton zone of Mali-Sud with a total of eleven (11) landscape units;b) There is great diversity at the specific level and in cropping systems. The mean values of the most specific indicator of diversity are recorded in villages where the mean rainfall is between 700 and 1000 mm of water followed by villages of less than 700 mm;c) The specific pressure indicator shows a geographical distribution of the pressures of the different crop species. Indeed, in villages where cotton is at the head of rotation, it exerts strong pressure on other species. In these villages, the cotton area is much larger than for the other species;d) For yield, most villages have average yields of cotton above the national average in 2015. Analyzing its evolution between 2013 and 2015, there is a decline in yield in most villages if this decline is very often sawtooth with increases in 2013 and 2014.e) The yield stability indicator shows that yields are stable with all species except maize.These results open the way for a greater contribution of geography in agronomic analysis.
La diversité des systèmes de culture et des variétés joue un rôle important dans la capacité des agricultures familiales à résister aux chocs socio-économiques et environnementaux. Pour une meilleure conservation, cette diversité agricole doit d’être caractérisée et suivie dans l’espace et le temps. Tandis qu’ils étaient dominés par des éléments sur le prix, les surfaces et les productions jusqu’à récemment, les systèmes de suivi agricole commencent à intégrer les questions de diversité. Alors que jusqu’à la fin des années 1990 elle était considérée comme un facteur limitant dans l’amélioration de la productivité des systèmes d’exploitations dans le processus de sélection variétale. Or dans une situation d’incertitude pluviométrique, pour réduire le risque de cet aléa, les agriculteurs ont recours à plusieurs espèces et variétés pour survivre et produire au travers de tous les aléas rencontrés. La stratégie paysanne consiste à cultiver à la fois plusieurs variétés présentant diverses caractéristiques agronomiques (précocité, rendement, résistance aux pathologies, aux parasites, à la sécheresse, etc.) et culinaires dans un même champ ou dans des champs différents. Cette stratégie permet aux paysans de cultiver les variétés s’adaptant le mieux aux conditions pédologiques de leurs champs et répondant à la fois à leurs divers besoins.C’est dans ce contexte que se situe la présente thèse qui vise principalement à analyser la structuration spatiale de l’agrobiodiversité dans la zone cotonnière. Pour atteindre cet objectif, plusieurs méthodes et approches ont été utilisées. L’approche adoptée combine l’analyse numérique d’images satellitaires et l’utilisation de données issues d’enquêtes de terrain. L’analyse de ces données s’appuie sur la distribution spatiale de la biodiversité et sa corrélation avec les pratiques et les conditions agro-écologiques, les résultats et les performances agronomiques.Les principaux résultats issus de l’analyse des données de l’étude sont :a) On observe une grande hétérogénéité et une diversité des paysages dans la zone cotonnière du Mali-Sud avec au total, onze (11) unités de paysages ;b) On constate une grande diversité au niveau spécifique et des systèmes de culture. Les valeurs moyennes de l’indicateur de diversités spécifiques les plus sont enregistrées dans les villages où la moyenne pluviométrique est comprise entre 700 à 1000 mm d’eau suivis par des villages de moins de 700 mm ;c) L’indicateur de pression spécifique montrant une répartition géographique des pressions des différentes espèces culturales. En effet dans les villages où le coton est en tête de rotation, il exerce une forte pression sur les autres espèces. Dans ces villages, la surface en coton est beaucoup plus importante que celle des autres espèces ;d) Le rendement fait constater que la plupart des villages ont des moyens de coton au-dessus de la moyenne nationale en 2015. En analysant son évolution entre 2013 et 2015, on constate une baisse de rendement dans la plupart des villages même si cette baisse est très souvent en dent de scie avec des hausses en 2013 et 2014.e) L’indicateur de stabilité du rendement montrant que les rendements sont stables avec toutes les espèces sauf le maïs.f) Ces résultats ouvrent la voie à une plus grande contribution de la géographie dans l’analyse agronomique.
sygal_fusion_27801-dembele-sidi.pdf (32.04 Mo) Télécharger le fichier
tel-03085785 , version 1 (22-12-2020)
  • HAL Id : tel-03085785 , version 1
Sidi Dembele. Structuration spatiale de la biodiversité agricole dans la zone cotonnière du Mali. Géographie. Normandie Université, 2018. Français. ⟨NNT : 2018NORMC046⟩. ⟨tel-03085785⟩
324 Consultations
33 Téléchargements
