Abstract : Within the framework of complex system design, such as aircraft and launch vehicles, the presence of computationallyintensive objective and/or constraint functions (e.g., finite element models and multidisciplinary analyses)coupled with the dependence on discrete and unordered technological design choices results in challenging optimizationproblems. Furthermore, part of these technological choices is associated to a number of specific continuous anddiscrete design variables which must be taken into consideration only if specific technological and/or architecturalchoices are made. As a result, the optimization problem which must be solved in order to determine the optimalsystem design presents a dynamically varying search space and feasibility domain.The few existing algorithms which allow solving this particular type of problems tend to require a large amountof function evaluations in order to converge to the feasible optimum, and result therefore inadequate when dealingwith the computationally intensive problems which can often be encountered within the design of complex systems.For this reason, this thesis explores the possibility of performing constrained mixed-variable and variable-size designspace optimization by relying on surrogate model-based design optimization performed with the help of Gaussianprocesses, also known as Bayesian optimization. More specifically, 3 main axes are discussed. First, the Gaussianprocess surrogate modeling of mixed continuous/discrete functions and the associated challenges are extensivelydiscussed. A unifying formalism is proposed in order to facilitate the description and comparison between theexisting kernels allowing to adapt Gaussian processes to the presence of discrete unordered variables. Furthermore,the actual modeling performances of these various kernels are tested and compared on a set of analytical and designrelated benchmarks with different characteristics and parameterizations.In the second part of the thesis, the possibility of extending the mixed continuous/discrete surrogate modeling toa context of Bayesian optimization is discussed. The theoretical feasibility of said extension in terms of objective/-constraint function modeling as well as acquisition function definition and optimization is shown. Different possiblealternatives are considered and described. Finally, the performance of the proposed optimization algorithm, withvarious kernels parameterizations and different initializations, is tested on a number of analytical and design relatedtest-cases and compared to reference algorithms.In the last part of this manuscript, two alternative ways of adapting the previously discussed mixed continuous/discrete Bayesian optimization algorithms in order to solve variable-size design space problems (i.e., problemscharacterized by a dynamically varying design space) are proposed. The first adaptation is based on the paralleloptimization of several sub-problems coupled with a computational budget allocation based on the informationprovided by the surrogate models. The second adaptation, instead, is based on the definition of a kernel allowingto compute the covariance between samples belonging to partially different search spaces based on the hierarchicalgrouping of design variables. Finally, the two alternatives are tested and compared on a set of analytical and designrelated benchmarks.Overall, it is shown that the proposed optimization methods allow to converge to the various constrained problemoptimum neighborhoods considerably faster when compared to the reference methods, thus representing apromising tool for the design of complex systems.
Résumé : Dans le cadre de la conception de systèmes complexes, tels que les aéronefs et les lanceurs, la présence de fonctions d'objectifs et/ou de contraintes à forte intensité de calcul (e.g., modèles d'éléments finis) couplée à la dépendance de choix de conception technologique discrets et non ordonnés entraîne des problèmes d'optimisation difficiles. De plus, une partie de ces choix technologiques est associée à un certain nombre de variables de conception continues et discrètes spécifiques qui ne doivent être prises en considération que si des choix technologiques spécifiques sont faits. Par conséquent, le problème d'optimisation qui doit être résolu afin de déterminer la conception optimale du système présente un espace de recherche et un domaine de faisabilité variant de façon dynamique. Les algorithmes existants qui permettent de résoudre ce type particulier de problèmes ont tendance à exiger une grande quantité d'évaluations de fonctions afin de converger vers l'optimum réalisable, et sont donc inadéquats lorsqu'il s'agit de résoudre les problèmes à forte intensité de calcul. Pour cette raison, cette thèse explore la possibilité d'effectuer une optimisation de l'espace de conception contraint à variables mixtes et de taille variable en s'appuyant sur des méthodes d’optimisation à base de modèles de substitution créés à l'aide de processus Gaussiens, également connue sous le nom d'optimisation Bayésienne. Plus spécifiquement, 3 axes principaux sont discutés. Premièrement, la modélisation de substitution par processus gaussien de fonctions mixtes continues/discrètes et les défis qui y sont associés sont discutés en détail. Un formalisme unificateur est proposé afin de faciliter la description et la comparaison entre les noyaux existants permettant d'adapter les processus gaussiens à la présence de variables discrètes non ordonnées. De plus, les performances réelles de modélisation de ces différents noyaux sont testées et comparées sur un ensemble de benchmarks analytiques et de conception ayant des caractéristiques et des paramétrages différents. Dans la deuxième partie de la thèse, la possibilité d'étendre la modélisation de substitution mixte continue/discrète à un contexte d'optimisation Bayésienne est discutée. La faisabilité théorique de cette extension en termes de modélisation de la fonction objectif/contrainte ainsi que de définition et d'optimisation de la fonction d'acquisition est démontrée. Différentes alternatives possibles sont considérées et décrites. Enfin, la performance de l'algorithme d'optimisation proposé, avec diverses paramétrisations des noyaux et différentes initialisations, est testée sur un certain nombre de cas-test analytiques et de conception et est comparée aux algorithmes de référence.Dans la dernière partie de ce manuscrit, deux approches permettant d'adapter les algorithmes d'optimisation bayésienne mixte continue/discrète discutés précédemment afin de résoudre des problèmes caractérisés par un espace de conception variant dynamiquement au cours de l’optimisation sont proposées. La première adaptation est basée sur l'optimisation parallèle de plusieurs sous-problèmes couplée à une allocation de budget de calcul basée sur l'information fournie par les modèles de substitution. La seconde adaptation, au contraire, est basée sur la définition d'un noyau permettant de calculer la covariance entre des échantillons appartenant à des espaces de recherche partiellement différents en fonction du regroupement hiérarchique des variables dimensionnelles. Enfin, les deux alternatives sont testées et comparées sur un ensemble de cas-test analytiques et de conception.Globalement, il est démontré que les méthodes d'optimisation proposées permettent de converger vers les optimums des différents types de problèmes considérablement plus rapidement par rapport aux méthodes existantes. Elles représentent donc un outil prometteur pour la conception de systèmes complexes.
