High-performance dense tensor and sparse matrix kernels for machine learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2020
Noyaux de calcul haute-performance de tenseurs denses et matrices creuses pour l’apprentissage automatique
In this thesis, we develop high performance algorithms for certain computations involving dense tensors and sparse matrices. We address kernel operations that are useful for machine learning tasks, such as inference with deep neural networks (DNNs). We develop data structures and techniques to reduce memory use, to improve data locality and hence to improve cache reuse of the kernel operations. We design both sequential and shared-memory parallel algorithms. In the first part of the thesis we focus on dense tensors kernels. Tensor kernels include the tensor--vector multiplication (TVM), tensor--matrix multiplication (TMM), and tensor--tensor multiplication (TTM). Among these, TVM is the most bandwidth-bound and constitutes a building block for many algorithms. We focus on this operation and develop a data structure and sequential and parallel algorithms for it. We propose a novel data structure which stores the tensor as blocks, which are ordered using the space-filling curve known as the Morton curve (or Z-curve). The key idea consists of dividing the tensor into blocks small enough to fit cache, and storing them according to the Morton order, while keeping a simple, multi-dimensional order on the individual elements within them. Thus, high performance BLAS routines can be used as microkernels for each block. We evaluate our techniques on a set of experiments. The results not only demonstrate superior performance of the proposed approach over the state-of-the-art variants by up to 18%, but also show that the proposed approach induces 71% less sample standard deviation for the TVM across the d possible modes. Finally, we show that our data structure naturally expands to other tensor kernels by demonstrating that it yields up to 38% higher performance for the higher-order power method. Finally, we investigate shared-memory parallel TVM algorithms which use the proposed data structure. Several alternative parallel algorithms were characterized theoretically and implemented using OpenMP to compare them experimentally. Our results on up to 8 socket systems show near peak performance for the proposed algorithm for 2, 3, 4, and 5-dimensional tensors. In the second part of the thesis, we explore the sparse computations in neural networks focusing on the high-performance sparse deep inference problem. The sparse DNN inference is the task of using sparse DNN networks to classify a batch of data elements forming, in our case, a sparse feature matrix. The performance of sparse inference hinges on efficient parallelization of the sparse matrix--sparse matrix multiplication (SpGEMM) repeated for each layer in the inference function. We first characterize efficient sequential SpGEMM algorithms for our use case. We then introduce the model-parallel inference, which uses a two-dimensional partitioning of the weight matrices obtained using the hypergraph partitioning software. The model-parallel variant uses barriers to synchronize at layers. Finally, we introduce tiling model-parallel and tiling hybrid algorithms, which increase cache reuse between the layers, and use a weak synchronization module to hide load imbalance and synchronization costs. We evaluate our techniques on the large network data from the IEEE HPEC 2019 Graph Challenge on shared-memory systems and report up to 2x times speed-up versus the baseline.
Dans cette thèse, nous développons des algorithmes à haute performance pour certains calculs impliquant des tenseurs denses et des matrices éparses. Nous abordons les opérations du noyau qui sont utiles pour les tâches d'apprentissage de la machine, telles que l'inférence avec les réseaux neuronaux profonds. Nous développons des structures de données et des techniques pour réduire l'utilisation de la mémoire, pour améliorer la localisation des données et donc pour améliorer la réutilisation du cache des opérations du noyau. Nous concevons des algorithmes parallèles à mémoire séquentielle et à mémoire partagée.Dans la première partie de la thèse, nous nous concentrons sur les noyaux tenseurs denses. Les noyaux tenseurs comprennent la multiplication tenseur-vecteur (TVM), la multiplication tenseur-matrice (TMM) et la multiplication tenseur-tendeur (TTM). Parmi ceux-ci, la MVT est la plus liée à la largeur de bande et constitue un élément de base pour de nombreux algorithmes. Nous proposons une nouvelle structure de données qui stocke le tenseur sous forme de blocs, qui sont ordonnés en utilisant la courbe de remplissage de l'espace connue sous le nom de courbe de Morton (ou courbe en Z). L'idée clé consiste à diviser le tenseur en blocs suffisamment petits pour tenir dans le cache et à les stocker selon l'ordre de Morton, tout en conservant un ordre simple et multidimensionnel sur les éléments individuels qui les composent. Ainsi, des routines BLAS haute performance peuvent être utilisées comme micro-noyaux pour chaque bloc. Les résultats démontrent non seulement que l'approche proposée est plus performante que les variantes de pointe jusqu'à 18%, mais aussi que l'approche proposée induit 71% de moins d'écart-type d'échantillon pour le MVT dans les différents modes possibles. Enfin, nous étudions des algorithmes de mémoire partagée parallèles pour la MVT qui utilisent la structure de données proposée. Nos résultats sur un maximum de 8 systèmes de prises montrent une performance presque maximale pour l'algorithme proposé pour les tenseurs à 2, 3, 4 et 5 dimensions.Dans la deuxième partie de la thèse, nous explorons les calculs épars dans les réseaux de neurones en nous concentrant sur le problème d'inférence profonde épars à haute performance. L'inférence sparse DNN est la tâche d'utiliser les réseaux sparse DNN pour classifier un lot d'éléments de données formant, dans notre cas, une matrice de caractéristiques sparse. La performance de l'inférence clairsemée dépend de la parallélisation efficace de la matrice clairsemée - la multiplication matricielle clairsemée (SpGEMM) répétée pour chaque couche dans la fonction d'inférence. Nous introduisons ensuite l'inférence modèle-parallèle, qui utilise un partitionnement bidimensionnel des matrices de poids obtenues à l'aide du logiciel de partitionnement des hypergraphes. Enfin, nous introduisons les algorithmes de tuilage modèle-parallèle et de tuilage hybride, qui augmentent la réutilisation du cache entre les couches, et utilisent un module de synchronisation faible pour cacher le déséquilibre de charge et les coûts de synchronisation. Nous évaluons nos techniques sur les données du grand réseau du IEEE HPEC 2019 Graph Challenge sur les systèmes à mémoire partagée et nous rapportons jusqu'à 2x l'accélération par rapport à la ligne de base.
PAWLOWSKI_Filip_2020LYSEN081_These.pdf (975.36 Ko) Télécharger le fichier
tel-03116812 , version 1 (20-01-2021)
  • HAL Id : tel-03116812 , version 1
Filip Igor Pawlowski. High-performance dense tensor and sparse matrix kernels for machine learning. Distributed, Parallel, and Cluster Computing [cs.DC]. Université de Lyon, 2020. English. ⟨NNT : 2020LYSEN081⟩. ⟨tel-03116812⟩
270 Consultations
375 Téléchargements
