Matching and mining in knowledge graphs of the Web of data - Applications in pharmacogenomics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2020
Appariement et fouille dans les graphes de connaissances du Web des données - Applications en pharmacogénomique
Pierre Monnin
In the Web of data, an increasing number of knowledge graphs are concurrently published, edited, and accessed by human and software agents. Their wide adoption makes key the two tasks of matching and mining. First, matching consists in identifying equivalent, more specific, or somewhat similar units within and across knowledge graphs. This task is crucial since concurrent publication and edition may result in coexisting and complementary knowledge graphs. However, this task is challenging because of the inherent heterogeneity of knowledge graphs, e.g., in terms of granularities, vocabularies, and completeness. Motivated by an application in pharmacogenomics, we propose two approaches to match n-ary relationships represented in knowledge graphs: a symbolic rule-based approach and a numeric approach using graph embedding. We experiment on PGxLOD, a knowledge graph that we semi-automatically built by integrating pharmacogenomic relationships from three distinct sources of this domain. Second, mining consists in discovering new and useful knowledge units from knowledge graphs. Their increasing size and combinatorial nature entail scalability issues, which we address in the mining of path patterns. We also propose Concept Annotation, a refinement approach extending Formal Concept Analysis, a mathematical framework that groups entities based on their common attributes. Throughout all our works, we particularly focus on taking advantage of domain knowledge in the form of ontologies that can be associated with knowledge graphs. We show that, when considered, such domain knowledge alleviates heterogeneity and scalability issues in matching and mining approaches.
Dans le Web des données, des graphes de connaissances de plus en plus nombreux sont simultanément publiés, édités, et utilisés par des agents humains et logiciels. Cette large adoption rend essentielles les tâches d'appariement et de fouille. L'appariement identifie des unités de connaissances équivalentes, plus spécifiques ou similaires au sein et entre graphes de connaissances. Cette tâche est cruciale car la publication et l'édition parallèles peuvent mener à des graphes de connaissances co-existants et complémentaires. Cependant, l'hétérogénéité inhérente aux graphes de connaissances (e.g., granularité, vocabulaires, ou complétude) rend cette tâche difficile. Motivés par une application en pharmacogénomique, nous proposons deux approches pour apparier des relations n-aires représentées au sein de graphes de connaissances : une méthode symbolique à base de règles et une méthode numérique basée sur le plongement de graphe. Nous les expérimentons sur PGxLOD, un graphe de connaissances que nous avons construit de manière semi-automatique en intégrant des relations pharmacogénomiques de trois sources du domaine. La tâche de fouille permet quant à elle de découvrir de nouvelles unités de connaissances à partir des graphes de connaissances. Leur taille croissante et leur nature combinatoire entraînent des problèmes de passage à l'échelle que nous étudions dans le cadre de la fouille de patrons de chemins. Nous proposons également l'annotation de concepts, une méthode d'amélioration des graphes de connaissances qui étend l'Analyse Formelle de Concepts, un cadre mathématique groupant des entités en fonction de leurs attributs communs. Au cours de tous nos travaux, nous nous sommes particulièrement intéressés à tirer parti des connaissances de domaines formalisées au sein d'ontologies qui peuvent être associées aux graphes de connaissances. Nous montrons notamment que, lorsqu'elles sont prises en compte, ces connaissances permettent de réduire l'impact des problèmes d'hétérogénéité et de passage à l'échelle dans les tâches d'appariement et de fouille.
thesis-pmonnin.pdf (7.66 Mo) Télécharger le fichier
tel-03122326 , version 1 (26-01-2021)
  • HAL Id : tel-03122326 , version 1
Pierre Monnin. Matching and mining in knowledge graphs of the Web of data - Applications in pharmacogenomics. Databases [cs.DB]. Université de Lorraine, 2020. English. ⟨NNT : 2020LORR0212⟩. ⟨tel-03122326⟩
428 Consultations
762 Téléchargements
