Changements à long terme de la structure et de la diversité des peuplements de poissons de fond du plateau continental de Guyane - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2020
Long-term changes in fish communities’ diversity and structure from the continental shelf of French Guiana
In the actual context of overfishing and climate change we need to develop an ecosystem-based management of fisheries. This thesis work will try to bring answers to this issue by analyzing community assembly and the impact of French Guiana’s fishery on fish communities. As most of tropical regions, coastal waters in French Guiana have been subjected to an increase in temperature around 1°C between 1990 and 2017. However, as for only a few regions in the world, fishing pressure has collapsed in French Guiana during the same period. This case study is therefore a good opportunity to understand how tropical fish communities have responded to a progressive decreasing fishing pressure on a large scale and under climate change constraints. The aim of this work is to provide useful information for tropical fisheries with similar characteristics which tend to a more efficient ecosystem-based management with lower fishing pressure. The study showed that the environment plays a dominant role in community structure and that it has become more important over time. Results showed also significant increases in several diversity indices and an increase in theoretical maximum size spectra of surveyed fish which indicates a restructuring of communities. This recovery is associated with an increase of functional redundancy which is a key factor for the stability of ecosystems. Global results showed a great recovery capacity towards a richer and more stable state of communities in a relatively short period of time around 10 years.
Dans le contexte actuel de surpêche et de réchauffement climatique, il est nécessaire d’adopter une gestion écosystémique des ressources halieutiques. Ce travail de thèse apporte des éléments de réponse à cette problématique en se penchant sur le cas de la pêcherie crevettière guyanaise et de son impact sur les communautés de poissons associées. Comme dans la plupart des régions tropicales, les eaux côtières de Guyane se sont réchauffées d’environ 1°C entre 1990 et 2017. En revanche, comme dans peu d’endroits au monde, la pression de pêche s’est quasiment effondrée sur cette même période. Ce cas d’étude est donc une bonne opportunité pour comprendre la réaction des communautés de poissons de cette région tropicale après une diminution progressive et à grande échelle de la pression de pêche dans un contexte de réchauffement climatique. Les résultats de ce travail montrent que les facteurs environnementaux jouent un rôle dominant dans la structuration des communautés de poissons marins en Guyane. Les analyses montrent notamment des augmentations de certains indicateurs de diversité, une augmentation du spectre des tailles maximales théoriques des espèces et une augmentation de la redondance fonctionnelle qui est un facteur clé pour la stabilité des peuplements. Ces éléments témoignent d’une restructuration des communautés et mettent en avant leur capacité à retrouver un état riche et stable en une période relativement courte d’une douzaine d’années voire moins. On observe néanmoins une tropicalisation des communautés qui pose des questions sur l’évolution future de la diversité des écosystèmes tropicaux au regard des différents scénarios climatiques.
THESE_Vincent_VALLEE.pdf (7.95 Mo) Télécharger le fichier
tel-03200837 , version 1 (16-04-2021)
  • HAL Id : tel-03200837 , version 1
Vincent Vallée. Changements à long terme de la structure et de la diversité des peuplements de poissons de fond du plateau continental de Guyane. Ecologie, Environnement. Université de Guyane, 2020. Français. ⟨NNT : 2020YANE0004⟩. ⟨tel-03200837⟩
278 Consultations
145 Téléchargements
