Model-based control and diagnosis of inland navigation networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2019
Contrôle et diagnostic à base de modèle de réseaux de navigation intérieure
This thesis addresses the problem of optimal management of water resources in inland navigation networks from a control theory perspective. The main objectives to be attained consist in guaranteeing the navigability condition of the network, minimizing the operational cost and ensuring a long lifespan of the equipment. However, their complex dynamics, large time delays and negligible bottom slopes complicate their management. In order to achieve the optimal management, the efficient control of the hydraulic structures must be ensured. To this end, a control-oriented modeling approach is derived. The resulting formulation belongs to the class of delayed desciptor systems, for which model predictive control and moving horizon estimation can be easily adapted, as well as being able to deal with physical and operational constraints in a natural manner. However, a centralized implementation is often neither possible nor desirable. As these networks are strongly coupled systems, a distributed approach is followed, featuring a communication protocol among agents. Despite the optimality of the solutions, any malfunction can lead to an inefficient system management. Therefore, the last part of the thesis regards the design of supervisory strategies that allow to detect and isolate faults. All the presented approaches are applied to a realistic case study based on the inland navigation network in the north of France to validate their effectiveness.
Cette thèse contribue à répondre au problème de la gestion optimale des ressources en eau dans les réseaux de navigation intérieure du point de vue de la théorie du contrôle. Les objectifs principales à atteindre consistent à garantir la navigabilité des réseaux de voies navigables, veiller à la réduction des coûts opérationnels et à la longue durée de vie des équipements. Lors de la conception de lois de contrôle, les caractéristiques des réseaux doivent être prises en compte, à savoir leurs dynamiques complexes, des retards variables et l’absence de pente. Afin de réaliser la gestion optimale, le contrôle efficace des structures hydrauliques doit être assuré. A cette fin, une approche de modélisation orientée contrôle est dérivée. Cependant, la formulation obtenue appartient à la classe des systèmes de descripteurs retardés, pour lesquels la commande prédictive MPC et l’estimation d’état sur horizon glissant MHE peuvent être facilement adaptés à cette formulation, tout en permettant de gérer les contraintes physiques et opérationnelles de manière naturelle. En raison de leur grande dimensionnalité, une mise en œuvre centralisée n’est souvent ni possible ni souhaitable. Compte tenu du fait que les réseaux de navigation intérieure sont des systèmes fortement couplés, une approche distribuée est proposée, incluant un protocole de communication entre agents. Malgré l’optimalité des solutions, toute erreur peut entraîner une gestion inefficace du système. Par conséquent, les dernières contributions de la thèse concernent la conception de stratégies de supervision permettant de détecter et d’isoler les pannes des équipements. Toutes les approches présentées sont appliquées à une étude de cas réaliste basée sur le réseau de voies navigables du nord e la France afin de valider leur efficacité.
these_segovia_castillo_pablo-vf.pdf (2.98 Mo) Télécharger le fichier
tel-03264828 , version 1 (18-06-2021)
  • HAL Id : tel-03264828 , version 1
Pablo Segovia Castillo. Model-based control and diagnosis of inland navigation networks. Automatic Control Engineering. Ecole nationale supérieure Mines-Télécom Lille Douai; Universitat politècnica de Catalunya - BarcelonaTech, 2019. English. ⟨NNT : 2019MTLD0003⟩. ⟨tel-03264828⟩
95 Consultations
105 Téléchargements
