Investigation of the rheological behavior of powders from the particle properties, application to a mixing/grinding process for the preparation of the MOX nuclear fuel
Analyse du comportement rhéologique des poudres à partir des propriétés des grains, application à l'étude d'un procédé de broyage/mélange pour la préparation du combustible nucléaire MOX
Up to now, the influence of the physico-chemical properties of the elementary particles on the flowability of bulk powders is still unclear. However, understanding the flow behavior of powders is of upmost importance for optimizing and operating process steps such as transport, storage or various unit process operations involving powders. In particular, the MiMas (Micronized Masterblend) process, implemented in MELOX plant for the preparation of MOX nuclear fuel, handles granular materials, mainly through mixing and grinding steps. In this study, various ceramic powders, essentially alumina, zirconia and yttria powders, have been finely characterized in terms of particle properties and rheological behavior with a powder shear tester. A model, involving the dimensionless granular Bond number to predict the macroscopic flow behavior of a polydispersed powder from its elementary particle properties has been extensively studied. In particular, this model was shown to predict successfully the flowability of binary and ternary mixtures as well as grinded powders according to the particles’ properties and as a function of the operating conditions, such as the composition of the blends or the grinding time. The characterization of grinded and co-grinded powders obtained in a ball mill under various conditions also allowed specifying the influence of various operating parameters, such as the grinding time, the rotating speed or the filling ratio of the vessel. These results were particularly useful for identifying the dimensionless parameters to take into account for the scale up of the grinding equipment. Finally, a methodology for quantifying the homogeneity of powder mixtures, shaped in pellets, at various scales has been developed in order to compare several mixing and co-grinding processes.
A ce jour, l’influence des propriétés physico-chimiques des grains élémentaires sur l’écoulement global des poudres n’est pas clairement établie. Pourtant, la connaissance des propriétés d’écoulement des poudres est capitale pour l’optimisation et le fonctionnement des étapes de transport, de stockage, ou encore pour des opérations unitaires de procédés mettant en jeu des poudres. En particulier, le procédé MiMas (Micronized Masterblend), mis en œuvre à l’usine MELOX pour la préparation du combustible nucléaire MOX, repose en grande partie sur la manutention de milieux granulaires, principalement à travers des étapes de mélange et de broyage. Dans cette étude, différentes poudres de céramique, essentiellement d’alumine, de zircone et d’oxyde d’yttrium, ont été caractérisées finement en termes de propriétés des grains et de comportement rhéologique à partir de tests de cisaillements. Un modèle, reposant sur le nombre adimensionnel de Bond granulaire et permettant de prédire la coulabilité macroscopique de poudres polydisperses à partir des propriétés des grains qui la constituent a été développé et validé. Celui-ci a notamment permis de prédire efficacement la coulabilité de mélanges binaires ou ternaires et de poudres broyées en fonction des propriétés des grains, de la composition des mélanges et du temps de broyage. La caractérisation des poudres broyées ou co-broyées dans un broyeur à boulets dans différentes conditions a également permis de préciser l’influence de différents paramètres opératoires tels que le temps de broyage, la vitesse de rotation ou le taux de remplissage de la jarre. Ces résultats ont notamment permis d’identifier les grandeurs adimensionnelles à prendre en compte en priorité pour un changement d’échelle du broyeur. Enfin, une méthodologie permettant de quantifier l’homogénéité de mélanges de poudres, mis sous la forme de pastilles, à différentes échelles a été mise en place dans le but de pouvoir comparer différents procédés de mélange et de co-broyage.
