DC Microgrid optimized energy management and real-time control of power systems for grid-connected and off-grid operating modes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2021
Gestion optimisée de l'énergie et contrôle en temps réel des systèmes électriques de microréseau DC pour les modes de fonctionnement connectés au réseau et hors réseau
Wenshuai Bai
  • Fonction : Auteur
This thesis focus on the research of the DC microgrid following two operation models: grid-connected mode, and off-grid mode including the islanded and isolated modes. The aim of this thesis is to propose a DC microgrid combining the advantages of the grid-connected or the off-grid mode, which named full DC microgrid. ln the full DC microgrid, the renewable energy sources, storage, and public grid are included, and the back-up sources also applied to reduce the load shedding. ln the full DC microgrid, a supervisory system is proposed to manage the power. The real-time power management in the operational layer of the supervisory system can keep the power balance. ln the optimization layer of the supervisory system, the day-ahead optimization is proposed to achieve the global minimal operation cost. The simulation results show that the full DC microgrid combines both advantages of the grid-connected and the off-grid mode to minimize the operating cost. Then, the supervisory system considers the dynamic efficiency of the converter to solve the problem that the power quality of the microgrid is degraded due to the unstable DC bus voltage caused by the inaccurate power control. The simulation results show that considering the dynamic efficiency of the converter in the operational layer of the supervisory system, the fluctuation of the DC bus voltage can be reduced. Regarding the importance of the PV prediction for the day-ahead optimization, two prediction modes are studied and compared to give a robust PV prediction power. The results are that the two models almost have the same results.
Le travail de recherche de cette thèse se concentre sur l’élaboration de deux modes de fonctionnement du microréseau à savoir : mode connecté au réseau, mode hors réseau comprenant les modes îloté et isolé. Le problème de la défaillance du réseau en mode connecté au réseau et la faible fiabilité de l'alimentation électrique en mode hors réseau doivent être résolues. Ainsi, le but de cette thèse est de proposer un microréseau DC combinant à la fois les avantages du mode connecté au réseau et ceux du mode isolé. On obtient ainsi un microréseau DC qu’on peut qualifier de complet. Le microréseau DC complet contient les sources d'énergie renouvelables, le stockage et le réseau public, et les sources de secours sont utilisées pour réduire le délestage. Dans ce microréseau DC, un système de supervision est proposé dans le but de gérer le flux des puissances. La gestion de la puissance en temps réel dans la couche opérationnelle du système de supervision permet de maintenir l'équilibre de puissance. Dans la couche d'optimisation du système de supervision, l'optimisation journalière est proposée afin de minimiser le coût d'exploitation global. Les résultats de la simulation montrent que le microréseau DC complet peut minimiser les coûts d'exploitation. Ensuite, le système de supervision prend en compte l'efficacité dynamique du convertisseur pour résoudre le problème lié à la qualité de la puissance du microréseau qui peut être dégradée à cause de la tension instable du bus DC. Les résultats de la simulation montrent que la prise en compte de l'efficacité dynamique du convertisseur dans la couche opérationnelle du système de supervision permet de réduire les fluctuations de la tension du bus DC. En ce qui concerne l'importance de la prédiction PV pour l'optimisation de la veille, deux modèles de prédiction sont étudiés et comparés pour donner une puissance de prédiction PV précise. Les résultats montrent que les deux modèles ont presque les mêmes résultats.
These_UTC_Wenshuai_Bai.pdf (16.8 Mo) Télécharger le fichier
tel-03313913 , version 1 (04-08-2021)
  • HAL Id : tel-03313913 , version 1
Wenshuai Bai. DC Microgrid optimized energy management and real-time control of power systems for grid-connected and off-grid operating modes. Electric power. Université de Technologie de Compiègne, 2021. English. ⟨NNT : 2021COMP2586⟩. ⟨tel-03313913⟩
324 Consultations
119 Téléchargements
