Discrete Logarithm Cryptanalyses : Number Field Sieve and Lattice Tools for Side-Channel Attacks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2021
Cryptanalyses de logarithmes discrets : crible algébrique et réseaux pour canaux auxiliaires
Public-key cryptosystems are constructed using one-way functions which ensure both the security and the efficiency of the schemes. One of the two main candidates originally considered to construct public-key cryptosystems is modular exponentiation with its hard inverse operation, computing discrete logarithms. In this thesis, we study the security of protocols that make use of modular exponentiation where the exponent is a secret of the protocol. To assess the security of such protocols, one can either estimate the hardness of directly solving the discrete logarithm problem (DLP) in the groups considered by the protocols or look at implementation vulnerabilities from fast exponentiation algorithms. One way of estimating the security of protocols based on the hardness of the discrete logarithm problem is to directly study the complexity of the algorithms that solve the latter. In this thesis, we first study the asymptotic complexity of algorithms that solve DLP over finite fields “\F_{p^n}” precisely of the form where pairings take their values. These algorithms come from the index-calculus family from which the Number Field Sieve (NFS) is an example. This study allows us to draw conclusions on the security of pairing-based protocols. We also propose a first implementation of the variant Tower Number Field Sieve (TNFS) of NFS, which has better asymptotic complexity, along with a record computation of a discrete logarithm in a 521-bit finite field with TNFS. This variant had never been implemented before due to the difficulty of sieving in higher dimensions, i.e., dimensions greater than two. Finally, the security of deployed protocols not only relies on the hardness of the underlying mathematical problem but also on the implementation of the algorithms involved. Many fast modular exponentiation algorithms have piled up over the years and some implementations have brought vulnerabilities that are exploitable by side-channel attacks, in particular cache attacks. The second aspect of this thesis thus considers key recover methods when partial information is recovered from a side channel.
Les cryptosystèmes dits à clé publique sont construits à l'aide de fonctions à sens unique qui assurent à la fois la sécurité et l'efficacité des cryptosystèmes. L'un des deux principaux candidats envisagés à l'origine pour construire de tels cryptosystèmes est l'exponentiation modulaire avec son opération inverse, le calcul de logarithmes discrets. Dans cette thèse, nous étudions la sécurité de protocoles qui utilisent des exponentiations modulaires où l'exposant est un secret du protocole. Afin d'évaluer la sécurité de tels protocoles, on peut d'une part estimer la difficulté de résoudre directement le problème du logarithme discret (DLP) dans les groupes considérés par les protocoles, ou examiner les vulnérabilités issues de l'implémentation des algorithmes d'exponentiation rapide. Une première façon d'estimer la sécurité des protocoles basés sur la difficulté du problème du logarithme discret est d'étudier directement la complexité des algorithmes qui résolvent ce dernier. Dans cette thèse, nous étudions la complexité asymptotique des algorithmes qui résolvent le DLP sur des corps finis « \F_{p^n} » précisément de la forme où les couplages prennent leurs valeurs. Nous proposons également une première implémentation et un calcul record d'un logarithme discret dans un corps fini de 521 bits en utilisant l'algorithme Tower Number Field Sieve, une variante de NFS dont la complexité asymptotique est meilleure. Cette variante n'avait jamais été implémentée auparavant en raison de la difficulté du crible algébrique dans des dimensions supérieures à deux. Enfin, la sécurité des protocoles déployés ne repose pas seulement sur la difficulté du problème mathématique sous-jacent, mais aussi sur l'implémentation des algorithmes considérés. De nombreux algorithmes d'exponentiation modulaire rapide se sont accumulés au fil des ans et certaines implémentations ont fait apparaître des vulnérabilités exploitables par des attaques par canaux auxiliaires. Un second aspect de cette thèse considère donc les principales méthodes pour reconstituer une clé secrète lorsque des informations partielles sont récupérées à partir d'un canal auxiliaire.
DDOC_T_2021_0104_DE_MICHELI.pdf (2.46 Mo) Télécharger le fichier
tel-03335360 , version 1 (06-09-2021)
  • HAL Id : tel-03335360 , version 1
Gabrielle de Micheli. Discrete Logarithm Cryptanalyses : Number Field Sieve and Lattice Tools for Side-Channel Attacks. Computer Science [cs]. Université de Lorraine, 2021. English. ⟨NNT : 2021LORR0104⟩. ⟨tel-03335360⟩
369 Consultations
798 Téléchargements
