Lexical emergence from context : exploring unsupervised learning approaches on large multimodal language corpora
L'émergence du lexique en contexte : apport des méthodes non supervisées sur grands corpus de données multimodales
In recent years, deep learning methods allowed the creation of neural models that are able to process several modalities at once. Neural models of Visually Grounded Speech (VGS) are such kind of models and are able to jointly process a spoken input and a matching visual input. They are commonly used to solve a speech-image retrieval task: given a spoken description, they are trained to retrieve the closest image that matches the description. Such models sparked interest in linguists and cognitive scientists as they are able to model complex interactions between two modalities --- speech and vision --- and can be used to simulate child language acquisition and, more specifically, lexical acquisition.In this thesis, we study a recurrent-based model of VGS and analyse the linguistic knowledge such models are able to derive as a by-product of the main task they are trained to solve. We introduce a novel data set that is suitable to train models of visually grounded speech. Contrary to most data sets that are in English, this data set is in Japanese and allows us to study the impact of the input language on the representations learnt by the neural models.We then focus on the analysis of the attention mechanisms of two VGS models, one trained on the English data set, the other on the Japanese data set, and show the models have developed a language-general behaviour by using their attention weights to focus on specific nouns in the spoken input. Our experiments reveal that such models are able to adopt a language-specific behaviour by taking into account particularities of the input language so as to better solve the task they are given.We then study if VGS models are able to map isolated words to their visual referents. This allows us to investigate if the model has implicitly segmented the spoken input into sub-units. We further investigate how isolated words are stored in the weights of the network by borrowing a methodology stemming from psycholinguistics, the gating paradigm, and show that word onset plays a major role in successful activation.Finally, we introduce a simple method to introduce segment boundary information in a neural model of speech processing. This allows us to test if the implicit segmentation that takes place in the network is as effective as an explicit segmentation. We investigate several types of boundaries, ranging from phone to word boundaries, and show the latter yield the best results. We observe that giving the network several boundaries at the same is beneficial. This allows the network to take into account the hierarchical nature of the linguistic input.
Ces dernières années, les méthodes d'apprentissage profond ont permis de créer des modèles neuronaux capables de traiter plusieurs modalités à la fois. Les modèles neuronaux de traitement de la Parole Visuellement Contextualisée (PVC) sont des modèles de ce type, capables de traiter conjointement une entrée vocale et une entrée visuelle correspondante. Ils sont couramment utilisés pour résoudre une tâche de recherche d'image à partir d'une requête vocale: c'est-à-dire qu'à partir d'une description orale, ils sont entraînés à retrouver l'image correspondant à la description orale passée en entrée. Ces modèles ont suscité l'intérêt des linguistes et des chercheurs en sciences cognitives car ils sont capables de modéliser des interactions complexes entre deux modalités --- la parole et la vision --- et peuvent être utilisés pour simuler l'acquisition du langage chez l'enfant, et plus particulièrement l'acquisition lexicale.Dans cette thèse, nous étudions un modèle récurrent de PVC et analysons les connaissances linguistiques que de tels modèles sont capables d'inférer comme sous-produit de la tâche principale pour laquelle ils sont entraînés. Nous introduisons un nouveau jeu de données qui convient à l'entraînement des modèles de PVC. Contrairement à la plupart des jeux de données qui sont en anglais, ce jeu de données est en japonais, ce qui permet d'étudier l'impact de la langue d'entrée sur les représentations apprises par les modèles neuronaux.Nous nous concentrons ensuite sur l'analyse des mécanismes d'attention de deux modèles de PVC, l'un entrainé sur le jeu de données en anglais, l'autre sur le jeu de données en japonais, et montrons que les modèles ont développé un comportement général, valable quelle que soit la langue utilisée, en utilisant leur poids d'attention pour se focaliser sur des noms spécifiques dans la chaîne parlée. Nos expériences révèlent que ces modèles sont également capables d'adopter un comportement spécifique à la langue en prenant en compte les particularités de la langue d'entrée afin de mieux résoudre la tâche qui leur est donnée.Nous étudions ensuite si les modèles de PVC sont capables d'associer des mots isolés à leurs référents visuels. Cela nous permet d'examiner si le modèle a implicitement segmenté l'entrée parlée en sous-unités. Nous étudions ensuite comment les mots isolés sont stockés dans les poids des réseaux en empruntant une méthodologie issue de la linguistique, le paradigme de gating, et nous montrons que la partie initiale du mot joue un rôle majeur pour une activation réussie.Enfin, nous présentons une méthode simple pour introduire des informations sur les frontières des segments dans un modèle neuronal de traitement de la parole. Cela nous permet de tester si la segmentation implicite qui a lieu dans le réseau est aussi efficace qu'une segmentation explicite. Nous étudions plusieurs types de frontières, allant des frontières de phones aux frontières de mots, et nous montrons que ces dernières donnent les meilleurs résultats. Nous observons que donner au réseau plusieurs frontières en même temps est bénéfique. Cela permet au réseau de prendre en compte la nature hiérarchique de l'entrée linguistique.
