Attack Modelling and Detection in Distributed and Cooperative Controlled Microgrid Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2021
Modélisation et détection des attaques dans les systèmes de contrôle distribué et coopératif de micro-réseaux électriques
Modern low-voltage microgrid systems rely on distributed and cooperative control approaches to guarantee safe and reliable operational decisions of their inverter-based distributed generators (DGs). However, many sophisticated cyber-attacks can target these systems, deceive their traditional detection methods and cause a severe impact on the power infrastructure. In this thesis, we systematically study the vulnerabilities and threats of distributed controlled microgrid systems. We design a novel attack named "measurement-as-reference" (MaR) attack and take it as a typical stealthy attack example to theoretically analyze the attack impact on the microgrid system and use numerical simulation results to verify the analysis. We provide mathematical models of possible false data injection (FDI) and denial of service (DoS) attacks in a representative distributed and cooperative controlled microgrid system. We propose a secure control framework with an attack detection module based on machine learning techniques. To validate the effectiveness of this framework, we implement two typical attacks, MaR attack and delay injection attack, on a hardware platform modeled after a microgrid system. We collect datasets from the platform and validate the performance of multiple categories of machine learning algorithms to detect such attacks. Our results show that tree-based classifiers (Decision Tree, Random Forest and AdaBoost) outperform other algorithms and achieve excellent performance in detecting normal behavior, delay injection and false data attacks.
Les micro-réseaux électriques s'appuient sur des approches de contrôle distribuées et coopératives pour garantir des décisions opérationnelles sûres et fiables de leurs générateurs distribués (DG). Cependant, de nombreuses cyber-attaques sophistiquées peuvent viser ces systèmes, tromper leurs méthodes de détection traditionnelles et avoir des conséquences importantes sur l'infrastructure électrique. Dans cette thèse, nous étudions les attaques ciblant les systèmes de contrôle associés à ces micro-réseaux. Nous avons développé dans un premier temps une nouvelle attaque nommée MaR (Measurement as Reference) qui cible les consignes de synchronisation échangées entre les entités du système de contrôle. Nous avons analysé par simulation numérique l'impact de cette attaque sur la stabilité du micro-réseau et la convergence du système de contrôle vers une consigne commune. Nous avons également développé des modèles d'analyse des attaques de type injection de fausses données et déni de service sur ces systèmes pour étudier leurs impacts et leur détection. Ensuite, nous avons proposé un framework qui permet de détecter ces attaques, en se basant sur l'apprentissage automatique des caractéristiques des paquets réseau échangés entres les entités d'un système de contrôle distribué. Nous avons mis en œuvre une plate-forme expérimentale représentative d'un micro-réseau électrique et son système de contrôle pour collecter des jeux de données et valider notre framework, en particulier son module de détection des attaques.Enfin, nous avons évalué les performances de différents algorithmes d'apprentissage automatique pour détecter les attaques que nous avons introduites sur la plate-forme expérimentale. Nos résultats montrent que les algorithmes basés sur les techniques d'arbres, à l'image des arbres de décision, les forêts aléatoire et AdaBoost offrent les meilleures performances en termes de précision et de justesse pour détecter les différentes attaques et les distinguer.
DDOC_T_2021_0111_MA.pdf (21.46 Mo) Télécharger le fichier
tel-03356948 , version 1 (28-09-2021)
  • HAL Id : tel-03356948 , version 1
Mingxiao Ma. Attack Modelling and Detection in Distributed and Cooperative Controlled Microgrid Systems. Computer Science [cs]. Université de Lorraine, 2021. English. ⟨NNT : 2021LORR0111⟩. ⟨tel-03356948⟩
202 Consultations
240 Téléchargements
