Advanced Control of Multilevel Power Converters for Weak Grid Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2020
Contrôle avancé des convertisseurs de puissance multi-niveaux pour applications sur réseaux faibles
With the progressive rise of the micro-grids incorporating renewable energy sources, a new electricity distribution paradigm is emerging. These new architectures interface uncontrolled consumers with intermittent energy sources, therefore imposing more stress on the conversion, storage and management of the energy.Power converters are adapting accordingly, in particular, with the development of multi-level converters, which allow higher power rates and better power quality than their predecessors with similar components, but whose control is becoming increasingly complex.Due to their hybrid nature, the control of power converters is traditionally split into two parts: on the one side, the continuous objectives related to the main interfacing function of the power converters, and, on the other side, the driving of their quantized power switches, known as the modulation strategy.In this context, the growing demands in efficiency, reliability, versatility and performance require a high level of intelligence of the complete control structure. To meet these requirements, the objectives of this research work are to address both the interfacing objectives and the inner driving of the converter into a single controller. This decision implies incorporating the non-linearity of power converters into the controller, equivalent to suppressing the traditional modulation block. Modulation is the traditional solution to linearize the inner operation of the converters. The Model Predictive Control (MPC) approach was chosen to handle the non-linearity and the diversity of control objectives that accompany power converters.The developed control algorithm combines graph theory, with Dijkstra, A* and other algorithms, with a special state-space model designed for switching systems to form a powerful universal tool capable of simultaneously manipulating the discrete and continuous nature of the converter and its environment. Switched state-space models are studied, leading to interesting results on stability and controllability concerning their application on power converters.The obtained controller is then tested in simulation, with various case studies: grid-connected and standalone inverter, rectifier and bidirectional operation. These situations are studied for three common multi-level topologies: Neutral Point-Clamped, Flying Capacitor and Cascaded H-Bridge. The exact same MPC structure is used for each and every one of the case studies, with adaptations of its internal behavior. This behavior is agglomerated in two functions: the prediction, containing the model of the converter, and the cost function, which translates the control requirements into the optimal problem solved by the algorithm. Changing the topology implies adjusting the model, without impacting the cost function, while modifying this function is sufficient to adapt to the different applications.The results show that the controller manages to directly drive the power switches according to the application, demonstrating a large variety of considerations and objectives. The overall performance of this unique structure is comparable to that of the multiple structures used for each of the studied cases, with the notable exception of rectifier operation mode, where the speed and range of possibilities are particularly interesting.In conclusion, the developed controller manages miscellaneous applications, topologies, objectives and constraints. While the traditional linear control structures have to change, often deeply, for different operation modes and control requirements, such modifications do not affect the control architecture of the designed MPC controller. This shows the versatility of the proposed solution and its universality, further demonstrated by its ability to adapt to different power converters without modifications. Finally, the complexity of the modulation is fully included in the structure, offering simplicity and flexibility to the control design.
Avec l’avènement des micros-réseaux incorporant les sources d’énergie renouvelable, un nouveau paradigme apparaît dans la distribution de l’électricité. Ces nouvelles architectures interfacent des consommateurs non contrôlés à des sources d’énergie intermittentes, plaçant de fortes contraintes sur les étapes de conversion, stockage et gestion de l’énergie.Les convertisseurs de puissance s’adaptent avec en particulier le développement des convertisseurs multiniveaux, qui supportent à composants égaux des puissances plus importantes que leurs prédécesseurs et assurent une meilleure qualité de l’énergie, mais dont le contrôle gagne en complexité.Du fait de leur nature hybride, le contrôle des convertisseurs de puissance est traditionnellement scindé en deux parties. D’un côté les objectifs continus liés à la fonction principale d’interfaçage des convertisseurs, de l’autre le pilotage des interrupteurs quantifiés qui le forment, la modulation.Dans ce contexte, les exigences croissantes en rendement, fiabilité, polyvalence et performance imposent un gain conséquent d’intelligence de l’ensemble de l’architecture de contrôle. Pour répondre à ces exigences, nous proposons de traiter à la fois les objectifs liés à la fonction d’interface des convertisseurs et ceux rattachés à leur nature avec un unique contrôleur. Cette décision implique d’incorporer la non-linéarité des convertisseurs de puissance au contrôleur. Une approche de Contrôle à Modèle Prédictif (MPC) a été retenue pour traiter cette non-linéarité ainsi que la diversité d’objectifs de contrôle qui accompagne les convertisseurs.L’algorithme développé combine la théorie des graphes, avec divers algorithmes comme ceux de Dijkstra et A* à un modèle d’état spécialisé pour les systèmes à commutation, formant ainsi un outil puissant et universel capable de manipuler et la nature discrète des interrupteurs de puissance et celle continue de son environnement. L’étude du modèle d’état utilisé pour les convertisseurs de puissance comme systèmes commutants conduit à des résultats concernant la stabilité et la contrôlabilité de ces systèmes.Le contrôleur obtenu est éprouvé en simulation, face à des cas d’applications variés : onduleur isolé ou connecté à un réseau, redresseur et convertisseur bidirectionnel. La même structure de contrôle est confrontée à chacune de ces situations pour trois topologies multi-niveaux : Neutral Point-Clamped, Flying Capacitor et Cascaded H-Bridge. La capacité d’adaptation du contrôleur est regroupée dans deux étapes : la prédiction, qui utilise le modèle du convertisseur, et la fonction de coût, qui traduit le cahier des charges en un problème d’optimisation résolu par l’algorithme. Changer de topologie implique de modifier le modèle, sans impact sur la fonction de coût, tandis que modifier cette fonction suffit à s’adapter aux différentes applications.Les résultats montrent que le contrôleur pilote directement les interrupteurs de puissance en fonction des objectifs. Les performances générales de cette structure unique sont comparables à celles des structures multiples utilisées pour chacun des cas étudiés, à l’exception notable du fonctionnement redresseur, où la rapidité et l’étendue des possibilités sont tout particulièrement intéressants.En conclusion, le contrôleur développé est capable de traiter un grand nombre d’applications, topologies, objectifs et contraintes. Alors que les modifications du cahier des charges ou des conditions de fonctionnement impactent souvent profondément les structures de contrôle linéaire, ces altérations ne modifient pas l’architecture du contrôleur MPC développé. Cela illustre la polyvalence de la solution proposée ainsi que son universalité, démontrée davantage par la capacité à s’adapter à des convertisseurs de puissance différents et sans modifications. Finalement, la complexité de la modulation est toute incluse dans la structure, offrant un gain de simplicité et de flexibilité au design du contrôle.
Electronique
JUPIN_SAMUEL_2020.pdf (21.5 Mo) Télécharger le fichier
tel-03466297 , version 1 (05-12-2021)
  • HAL Id : tel-03466297 , version 1
Samuel Jupin. Advanced Control of Multilevel Power Converters for Weak Grid Applications. Electronics. Université de Bordeaux; Universidad del País Vasco, 2020. English. ⟨NNT : 2020BORD0210⟩. ⟨tel-03466297⟩
Collections
STAR U-BORDEAUX
186 Consultations
50 Téléchargements
