Entropic Unbalanced Optimal Transport: Application to Full-Waveform Inversion and Numerical Illustration
Transport optimal entropique : applications dans le contexte de l'inversion de forme d'onde.
Seismic tomography aims at inferring physical properties and reconstructing quantitatively the “model”, i.e. structures of the Earth interior, from the mechanical waves – radiated by natural and man-made seismic sources – that are recorded at the surface by receivers in the form of seis-mograms. Over the past decades, Full-Waveform inversion (FWI) has been actively developed in both academia and industry, and has proven to be a powerful tool that dramatically improved the capability to estimate physical properties and structures of various geological targets from global to local scales.
Full-waveform inversion (FWI) is formulated as a nonlinear, PDE-based optimisation problem that is classically solved by iterative minimisation of an objective function – measuring the misÿt bet-ween synthetic and observed seismic waveforms – using adjoint-based solution methods. Adjoint-based solution methods allow the computation of the derivative of the objective function with respect to the model parameters by combining the synthetic forward waveÿeld and an adjoint waveÿeld governed by a set of adjoint equations and adjoint subsidiary conditions.
In practice, however, solving FWI problems using local, nonlinear optimisation methods is facing challenges that preclude routine use. The quality of the inversion, simultaneously dealing with long and short wavelengths information, is degraded by the lack of low frequencies and also depends on a good starting model. These limitations are linked to the ill-posed nature of the inverse problem which can be easily trapped into a local minimum.
One proposed research direction to reduce the dependency on the initial model, is to replace the classical least-squares based misÿt by other objective functions – possibly involving nonlinear transformation of the seismic signal –hence promoting the convexity and trying to enlarge the basin of attraction of the global minimum.
Optimal Transport (OT) theory has recently been use in inverse problems and machine learning. Optimal Transport lifts the properties of the squared Euclidean distance to the space of probability distributions. The optimal value (squared) of the transport itself deÿnes a distance called the 2-Wasserstein distance. This quantity is again convex but now on the set of probability distributions.
This trend is already active for FWI, this thesis is part of it. The OT approach is still largely open on three fronts : Seismic Waveforms are not probability distributions, lacking positivity and nor-malised total mass. Convexity with respect to the model is not guaranteed and ÿnally the actual computation of the OT distance is not cheap.
In this work we use and combine – from an academic point of view – two recent extensions of OT in the context of FWI. First the “unbalanced” OT distance, which rigorously deÿnes a distance on the set of positive Radon measure thus by-passing the data normalisation issue (but not the positivity problem). Then, the entropic regularisation OT framework and in particular the simple and easy to compute variant called Sinkhorn divergence providing a good approximation of the 2-Wasserstein distance. The Sinkhorn divergence can be naturally extended to unbalanced OT.
We use these tools to construct and implement our unbalanced OT misÿt and discuss its use in the context of full-waveform inversion through a number of academic examples and classical benchmark problems.
Les méthodes de tomographie sismique visent à inférer les propriétés physique et reconstruire le “modèle”, i.e. les structures de l’intérieur de la Terre, à partir des ondes mécaniques - radiées par des sources naturelles ou anthropogéniques - enregistrées par des récepteurs en surface sous la forme de sismogrammes. Les méthodes d’inversion de formes d’onde ont été activement déve-loppées dans les contextes académiques et industriels et sont devenus des outils puissants pour améliorer l’estimation des propriétés physiques et des structures d’objets géologiques depuis les échelles globales jusqu’aux échelles locales de la géophysique d’exploration.
L’inversion de formes d’onde est formulée comme un problème d’optimisation non linéaire, as-socié à un système d’équations aux dérivées partielles. Il est classiquement résolu par des mé-thodes d’optimisation locale via la minimisation itérative d’une fonction coût qui mesure la di˙é-rence entre les sismogrammes observés et synthétiques, et utilisent des méthodes d’état adjoint. Les méthodes d’état adjoint permettent le calcul des dérivées de la fonction coût par rapport aux paramètres du modèle en combinant le champ d’onde direct et un champ d’onde adjoint gou-verné par un système d’équations adjointes et des conditions adjointes complémentaires.
Les méthodes d’inversion de forme d’onde, qui inversent simultanément les courtes et grandes longueurs d’onde, sou˙rent malheureusement en pratique de di°cultés qui restreignent leur uti-lisation pratique. Leurs capacités se détériorent du fait du déÿcit en basse fréquence des obser-vations et d’un bon modèle initial. Des limitations qui sont associées à la nature mal posée du problème inverse qui peut facilement être piégé dans un minimum local.
Une direction proposée, aÿn de réduire la dépendance vis à vis du modèle initial, est de rem-placer la fonction classique, basée sur une distance de type moindres carrés, par de nouvelles fonctions coûts, pouvant impliquer une transformation non linéaire du signal, aÿn de promouvoir la convexité et élargir le bassin d’attraction du minimum global.
La théorie du Transport Optimal (OT) a récemment été utilisée dans le cadre des problèmes in-verses et de l’apprentissage automatique. Le transport optimal généralise les propriétés de la distance euclidienne au carré à l’espace des distributions de probabilité. La valeur optimale (au carré) du transport lui-même déÿnit une distance appelée distance 2-Wasserstein. Cette quantité est à nouveau convexe mais maintenant sur l’ensemble des distributions de probabilité.
Le Transport Optimal est déjà utilisé en FWI, cette thèse en fait partie. L’approche OT est encore largement ouverte sur trois fronts : les formes d’onde sismiques ne sont ni positives ni de masse totale normalisée. La convexité par rapport au modèle n’est pas garantie et ÿnalement le calcul réel de la distance OT est coûteuse.
Dans ce travail, nous utilisons et combinons - d’un point de vue académique - deux extensions ré-centes d’OT dans le contexte FWI. D’abord la distance OT “non-équilibrée”, qui déÿnit rigoureuse-ment une distance sur l’ensemble des mesures de Radon positives contournant ainsi le problème de normalisation des données (mais pas le problème de positivité). Puis le cadre du Transport Optimal entropique et en particulier la variante simple et facile à calculer appelée divergence de Sinkhorn fournissant une bonne approximation de la distance 2-Wasserstein. La divergence de Sinkhorn peut être naturellement étendue au transport “non-équilibré”.
Nous utilisons ces outils pour construire et mettre en œuvre une fonction coût OT “non-équilibrée”. Nous discutons de son utilisation dans le contexte FWI au travers d’un certain nombre d’exemples académiques et de problèmes de référence classiques.
