Li-ion battery modeling in ultra-fast charge conditions
Contribution à la modélisation de batteries lithium ion : optimisation des charges rapides par rapport à la réaction de dépôt de lithium métal
Lithium deposition reaction is a local and undesirable phenomenon within Li-ion batteries. It is widely describe in the literature as one of the major limiting phenomena of rapid Li-ion cell loading. The control ofthis reactio in real time therefore seems to be a key factor for an optmal fast charging. This is classically studied by ve complex physical models and using experimental techniques requiring invasive tests on battery. As part of th study ofthis thesis, a methodology has been established, including a simplified modelling as well as non-invasiv experimental characterizations of Li-ion, to estimate all charging currents close to the limit of the lithiu deposition reaction. Experimental studies have been conducted on a graphite/LFP cell to validate these current and this resulted in a charging protocol where the current evolves With the load state and temperature of the cel It has been observed that these currents allow the cell to be charged ultra quickly without triggering the lithiu metal deposition reaction. For a charge at 0°, the cell has been recharged in 11 minutes between 10% and 87% of the state of charge. It has been validated that the estimated currents are close to, less than 10%, the « real » lim for triggering the lithium deposition reaction. Finally, by comparing cycling With these estimated limit curren and the charge at IC, no additional aging has been observed after more than 100 cycles at 0°.
La réaction de dépôt de lithium est un phénomène local et indésirable au sein des batteries Li-ion. Elle est largement décrite dans la littérature comme l'un des principaux phénomènes limitants de la charge rapide des cellules Li-ion. Le contrôle de cette réaction en temps réel est donc un facteur clé pour parvenir à la charge "au plus juste" d'un batterie Li-ion. Cela est classiquement étudié par des modèles physiques complexes et à l'aide des techniques expérimentales nécessitant des analyses invasives de la batterie. Dans le cadre de l'étude de cette thèse, il a été mis en place une méthodologie, incluant une modélisation simplifiée ainsi que des caractérisations expérimentales non invasives des cellules Li-ion, pour estimer l'ensemble des courants de recharge proche de la limite de la réaction de dépôt de lithium. Des études expérimentales ont été menées sur une cellule graphite/LFP pour valider ce courant et cela a donné lieu à un protocole de recharge où le courant évolue avec l'état de charge et la température de la cellule. Il a été observé que ces courants permettent de charger ultra rapidement la cellule sans que la réaction de dépôt de lithium métal ne soit déclenchée. Pour une charge à 0°, la cellule a été chargée en 11 minutes entre 10% et 87% d'état de charge. Il a été validé que les courants estimés sont proches, à moins de 10%, de la limite « réelle » de déclenchement de la réaction de dépôt de lithium. Enfin, en comparant les cyclages avec ces courants limites estimés et la charge à 1C, aucun vieillissement additionnel n'a été observé après plus de 100 cycles à 0°.
