Synthesis of composites based on recycled PP - Clay for textiles applications
Synthèse de composites à base de PP recyclé - Argile pour des applications textiles
Polypropylene PP is considered to be one of the most promising polyolefin polymer in compounding applications thanks to its good processability and excellent properties, as well as its low cost and density. This polymer is widely used in several applications, such as automotive components, aerospace, plastic parts, food packaging and geotextiles. Nevertheless, the performance of reused PP is proved to be insufficient in many applications, particularly with regard to its thermo-mechanical properties. However, recycled PP could acquire desired properties by incorporating fillers into polymer matrix. The objective of the thesis initially was studied the influence of organoclay on the physical, rheological, mechanical and thermal stability of recycled PP. In the following step, the prepared composite was then made into filamentsvia a melt spinning technique. The morphological and thermo-mechanical properties as well as the dyeability of the prepared filament were evaluated. The objective here is to exploit the elaborated composite in textile applications. Finally, all of its approaches and scientific studies allowed us to control the parameters of PP reuse and to open the way for new applications such as filters for treatment stations of textile dyeing waste in Tunisia.
Le polypropylène (PP) est un thermoplastique très utilisé dans la production industrielle. Il répond aux exigences de nombreux cahiers de charges grâce à ses excellentes propriétés tout en ayant une des plus faibles densités. Cependant, ses performances s’avèrent parfois insuffisantes lors de son recyclage, notamment en ce qui concerne ses propriétés thermiques et mécaniques. Pour pouvoir le réutiliser, le polymère doit être renforcé. Entre autres, l’adjonction de particules de renfort à la matrice de PP recyclé semble être une méthode efficace qui permet d’obtenir un composite avec de bonnes propriétés.Ainsi, l'objectif de notre thèse a été d'étudier l'influence de la concentration en argile tunisienne modifiée chimiquement sur les comportements thermo-mécaniques et rhéologiques du PP recyclé. Les divers mélanges mis en œuvre par extrusion ont été filés à l’aide d’un procédé de filage à l’état fondu. Une étude morphologique, thermo-mécanique et tinctoriale de la structure filamentaire élaborée est effectuée. Toutes ces approches nous ont permis de maîtriser les paramètres de réutilisation du PP et d'ouvrir la voie à de nouvelles applications, comme par exemple en tant que filtres pour les stations de retraitement des rejets de teinture dans le domaine de l’ennoblissement.
