Tool action : from consequence to functionality
Action outillée : de la conséquence à la fonctionnalité
This thesis is part of the field of work that tries to understand the mechanisms involved in the realization of tool actions. In psychology, two approaches confront each other on the subject, the first one suggests that the use of tools is primarily based on motor representations, the second approach proposes that reasoning in order to solve a problem is at the heart of the tool action. The thesis we defend is that the consequences of the tool action on the environment constitute a basis for the emergence of new functionalities for a tool. To this end, we have proposed five experiments. The first two aim at questioning the role of the bodily dimensions in 1) our perception of the tools and 2) the understanding of the action. The next two experiments aim at understanding 3) the impact of the consequence of the tool action on the memorization of a scene with a tool, 4) the durability of the learning of a link between a tool and a consequence, and 5) the influence of the consequence on the judgments about the tool. As a result of this work, the thesis we support suggests that we are constantly constructing new functionalities in the environment, and that we thus bring out new possibilities of action from the dialectical interaction between the environment and ourselves.
Ce travail de thèse s’inscrit dans le champ des travaux qui essayent comprendre les mécanismes impliqués dans la réalisation d’actions outillées. En psychologie deux approches se confrontent sur le sujet, la première suggère que l’utilisation d’outil soit avant tout basée sur des représentations motrices, la seconde approche propose que ce soit le raisonnement en vue de résoudre un problème qui soit au cœur de l’action outillée. La thèse que nous défendons est que les conséquences de l’action outillée sur l’environnement constituent une base pour l’émergence de fonctionnalités nouvelles pour un outil. Pour cela, nous avons proposé cinq expérimentations. Les deux premières visent à interroger le rôle des dimensions corporelles dans 1) notre perception des outils et 2) la compréhension de l’action. Les suivantes se proposent d’appréhender 3) l’impact de la conséquence de l’action outillée sur la mémorisation d’une scène avec un outil, 4) la durabilité de l’apprentissage d’un lien entre un outil et une conséquence, et 5) l’influence de la conséquence sur les jugements à propos de l’outil. Suite à ces travaux, la thèse que nous soutenons suggère que nous construisons en permanence des fonctionnalités nouvelles dans l’environnement, et que nous faisons ainsi émerger de l’interaction dialectique entre l’environnement et nous de nouvelles possibilités d’agir.
Psychologie
