Sur certaines méthodes raisonnées pour l'apprentissage par renforcement profond - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2022
Some Principled Methods for Deep Reinforcement Learning
This thesis develops and studies some principled methods for Deep Learning (DL) and deep Reinforcement Learning (RL).In Part II, we study the efficiency of DL models from the context of the Minimum Description Length principle, which formalize Occam's razor, and holds that a good model of data is a model that is good at losslessly compressing the data, including the cost of describing the model itself. Deep neural networks might seem to go against this principle given the large number of parameters to be encoded. Surprisingly, we demonstrate experimentally the ability of deep neural networks to compress the training data even when accounting for parameter encoding, hence showing that DL approaches are well principled from this information theory viewpoint.In Part III, we tackle two limitations of standard approaches in DL and RL, and develop principled methods, improving robustness empirically.The first one concerns optimisation of deep learning models with SGD, and the cost of finding the optimal learning rate, which prevents using a new method out of the box without hyperparameter tuning. When design a principled optimisation method for DL, 'All Learning Rates At Once' : each unit or feature in the network gets its own learning rate sampled from a random distribution spanning several orders of magnitude. Perhaps surprisingly, Alrao performs close to SGD with an optimally tuned learning rate, for various architectures and problems.The second one tackles near continuous-time RL environments (such as robotics, control environment, …) : we show that time discretization (number of action per second) in as a critical factor, and that empirically, Q-learning-based approaches collapse with small time steps. Formally, we prove that Q-learning does not exist in continuous time. We detail a principled way to build an off-policy RL algorithm that yields similar performances over a wide range of time discretizations, and confirm this robustness empirically.The main part of this thesis, (Part IV), studies the Successor States Operator in RL, and how it can improve sample efficiency of policy evaluation. In an environment with a very sparse reward, learning the value function is a hard problem. At the beginning of training, no learning will occur until a reward is observed. This highlight the fact that not all the observed information is used. Leveraging this information might lead to better sample efficiency. The Successor State Operator is an object that expresses the value functions of all possible reward functions for a given, fixed policy. Learning the successor state operator can be done without reward signals, and can extract information from every observed transition, illustrating an unsupervised reinforcement learning approach.We offer a formal treatment of these objects in both finite and continuous spaces with function approximators. We present several learning algorithms and associated results. Similarly to the value function, the successor states operator satisfies a Bellman equation. Additionally, it also satisfies two other fixed point equations: a backward Bellman equation and a Bellman-Newton equation, expressing path compositionality in the Markov process. These new relation allow us to generalize from observed trajectories in several ways, potentially leading to more sample efficiency. Every of these equations lead to corresponding algorithms for any function approximators such as neural networks.Finally, (Part V) the study of the successor states operator and its algorithms allow us to derive unbiased methods in the setting of multi-goal RL, dealing with the issue of extremely sparse rewards. We additionally show that the popular Hindsight Experience Replay algorithm, known to be biased, is actually unbiased in the large class of deterministic environments.
Cette thèse développe et étudie certaines méthodes de principe pour l'apprentissage profond (DL) et l'apprentissage par renforcement (RL).Dans la partie II, nous étudions le DL selon le point de vue du “Minimum Description Length” principe, qui formalise le rasoir d'Occam, et postule qu'un bon modèle prédictif est un modèle capable de compresser sans perte les données (en prenant en compte le coût de la description du modèle lui-même). Les modèles de DL, par le nombre de paramètres à encoder, semblent aller à l'encontre de ce principe. Nous démontrons expérimentalement la capacité de compression des modèles de DL, même en tenant compte de l'encodage des paramètres, montrant ainsi que ces approches sont bien fondées du point de vue de la théorie de l'information.Dans la partie III, nous étudions deux limitations des approches standard de DL et RL, et nous développons des méthodes mathématiquement bien fondées pour les dépasser;La première concerne l'optimisation des modèles de DL avec SGD, et le coût important du choix d'un bon taux d'apprentissage. Nous introduisons la méthode Alrao (All learning rates at once) : chaque unité (ou neurone) du réseau obtient son propre taux d'apprentissage tiré aléatoirement à partir d'une distribution couvrant de nombreux ordres de grandeur. De façon surprenante, Alrao obtient des résultats proches de ceux de SGD avec un taux d'apprentissage optimal, et ce pour diverses architectures et problèmes.Le second aborde les environnements de RL en temps quasi continu (robotique, contrôle, jeux vidéos,…) : nous montrons que la discrétisation temporelle (nombre d'actions par seconde) est un facteur critique, et empiriquement que les approches basées sur Q-learning ne peuvent plus apprendre quand le nombre d'action par seconde devient grand. Formellement, nous prouvons que le Q-learning n'existe pas en temps continu. Nous détaillons une méthode mathématiquement bien fondée pour construire un algorithme RL invariant à la discrétisation temporelle, et confirmons cette approche empiriquement.La partie principale de cette thèse, (Partie IV), étudie l'opérateur des états successeurs en RL, et comment il peut améliorer l'efficacité de l'apprentissage de la fonction valeur.Dans un environnement où la récompense n'est reçue que très rarement, l'apprentissage de la fonction valeur est un problème difficile. L'opérateur des états successeurs est un objet mathématique qui exprime les fonctions valeur de toutes les fonctions de récompense possibles pour une politique fixe. L'apprentissage de cet opérateur peut se faire sans signaux de récompense et peut extraire des informations de chaque transition observée, illustrant une approche de RL non supervisé.Nous proposons un traitement formel de cet objet dans des espaces finis et continus avec des approximateurs de fonctions, comme les réseaux de neurones. Nous présentons plusieurs algorithmes d'apprentissage et les résultats associés. De même que la fonction valeur, l'opérateur des états successeurs satisfait une équation de Bellman. De plus, il satisfait également deux autres équations à point fixe : une équation de Bellman en arrière et une équation de Bellman-Newton, exprimant la compositionalité des chemins dans le processus de Markov. Ces nouvelles relations nous permettent de généraliser à partir des trajectoires observées de plusieurs façons, ce qui peut conduire à une plus grande efficacité en pratique.Enfin, (partie V), l'étude de l'opérateur des états successeurs et de ses algorithmes nous permet de dériver des méthodes non biaisées dans le cadre d'un RL à buts multiples. Nous montrons en outre que l'algorithme Hindsight Experience Replay, populaire dans ce cadre mais connu pour être biaisé, est en fait non biaisé dans la classe importante des environnements déterministes.
109724_BLIER_2022_archivage.pdf (12.03 Mo) Télécharger le fichier
tel-03829500 , version 1 (25-10-2022)
  • HAL Id : tel-03829500 , version 1
Léonard Blier. Sur certaines méthodes raisonnées pour l'apprentissage par renforcement profond. Apprentissage [cs.LG]. Université Paris-Saclay, 2022. Français. ⟨NNT : 2022UPASG040⟩. ⟨tel-03829500⟩
245 Consultations
81 Téléchargements
