When Bilevel Optimization Meets Gas Networks: Feasibility of Bookings in the European Entry-Exit Gas Market
Quand l'optimisation à deux niveaux rencontre les réseaux de gaz : Faisabilité des réservations sur le marché européen entrée-sortie du gaz
Transport and trade of gas are decoupled after the liberalization of the European gas
markets, which are now organized as so-called entry-exit systems. At the core of this
market system are bookings and nominations, two special capacity-right contracts
that grant traders access to the gas network. The latter is operated by a separate
entity, known as the transmission system operator (TSO), who is in charge of the
transport of gas from entry to exit nodes. In the mid to long term, traders sign
a booking contract with the TSO to obtain injection and withdrawal capacities at
entry and exit nodes, respectively. On a day-ahead basis, they then nominate within
these booked capacities a balanced load flow of the planned amounts of gas to be
injected into and withdrawn from the network the next day. The key property is
that by signing a booking contract, the TSO is obliged to guarantee transportability
for all balanced load flows in compliance with the booked capacities. To assess the
feasibility of a booking, it is therefore necessary to check the feasibility of infinitely
many nominations. As a result, deciding if a booking is feasible is a challenging
mathematical problem, which we investigate in this dissertation.
Our results range from passive networks, consisting of pipes only, to active
networks, containing controllable elements to influence gas flows. Since the study of
the latter naturally leads to a bilevel framework, we first consider some more general
properties of bilevel optimization. For the case of linear bilevel optimization, we
consider the hardness of validating the correctness of big-M s often used in solving
these problems via a single-level reformulation. We also derive a family of valid
inequalities to be used in a bilevel-tailored branch-and-cut algorithm as a big-M -free
alternative.
We then turn to the study of feasible bookings. First, we present our results on
passive networks, for which bilevel approaches are not required. A characterization of
feasible bookings on passive networks is derived in terms of a finite set of nominations.
While computing these nominations is a difficult task in general, we present polynomial
complexity results for the special cases of tree-shaped or single-cycle passive networks.
Finally, we consider networks with linearly modeled active elements. After obtaining
a bilevel optimization model that allows us to determine the feasibility of a booking
in this case, we derive various single-level reformulations to solve the problem. In
addition, we obtain novel characterizations of feasible bookings on active networks,
which generalize our characterization in the passive case. The performance of these
various approaches is compared in a case study on two networks from the literature,
one of which is a simplified version of the Greek gas network.
Transport et commerce de gaz sont découplés depuis la libéralisation des marchés
européens du gaz, qui sont désormais organisés en systèmes dit d’entrée-sortie. Au
cœur de ce système de marché se trouvent les réservations et les nominations, deux
contrats spéciaux de droit à la capacité qui permettent aux négociants d’accéder au
réseau de gaz. Ce dernier est exploité par une entité distincte, appelée gestionnaire
de réseau de transport (GRT), qui est chargée du transport du gaz entre les nœuds
d’entrée et de sortie. À moyen et long terme, les négociants signent un contrat de
réservation avec le GRT pour obtenir des capacités d’injection et d’extraction aux
nœuds d’entrée et de sortie, respectivement. Au jour le jour, ils désignent ensuite,
dans les limites des capacités réservées, un flux de charge équilibrée des quantités de
gaz prévues à injecter et à extraire le lendemain. La propriété essentielle est qu’en
signant un contrat de réservation, le GRT est obligé de garantir la transportabilité
de tous les flux de charge équilibrée respectant les capacités réservées. Pour évaluer
la faisabilité d’une réservation, il est donc nécessaire de vérifier la faisabilité d’une
infinité de nominations. Par conséquent, décider si une réservation est réalisable est
un problème mathématique difficile, que nous étudions dans cette thèse.
Nos résultats vont des réseaux passifs, constitués uniquement de pipelines, aux
réseaux actifs, contenant des éléments contrôlables pour influencer les flux de gaz.
Comme l’étude de ces derniers conduit naturellement à un cadre biniveau, nous
considérons d’abord certaines propriétés plus générales de l’optimisation biniveau.
Pour le cas de l’optimisation biniveau linéaire, nous étudions la difficulté de valider
l’exactitude des constantes de type big-M souvent utilisées dans la résolution de ces
problèmes via une reformulation à un seul niveau. Nous déduisons également une
famille d’inégalités valides à utiliser dans un algorithme de branch-and-cut adapté au
biniveau comme alternative à l’approche utilisant des big-M s.
Nous nous tournons ensuite vers l’étude des réservations réalisables. D’abord,
nous présentons nos résultats sur les réseaux passifs, pour lesquels les approches
biniveaux ne sont pas nécessaires. Une caractérisation des réservations réalisables
sur les réseaux passifs est déduite en termes d’un ensemble fini de nominations. Bien
que le calcul de ces nominations soit une tâche difficile en général, nous présentons
des algorithmes polynomiaux pour les cas particuliers des réseaux passifs en forme
d’arbre ou contenant un cycle unique. Enfin, nous considérons les réseaux avec des
éléments actifs modélisés à l’aide de contraintes linéaires. Après avoir obtenu un
modèle biniveau, permettant de déterminer la faisabilité d’une réservation dans ce
cas, nous dérivons diverses reformulations à un seul niveau pour résoudre le problème.
En outre, nous obtenons de nouvelles caractérisations des réservations réalisables
sur les réseaux actifs, qui généralisent notre caractérisation dans le cas passif. La
performance de ces différentes approches est comparée dans une étude de cas réalisée
sur deux réseaux de la littérature, dont l’un est une version simplifiée du réseau de
gaz grec.
