Trajectoires des acteurs et construction du champ de l’ESS. Eclairages réciproques Argentine-Bulgarie - Anuario Americanista Europeo Accéder directement au contenu
Thèse Année : 2020
Actors' trajectories and the construction of the SSE field. Reciprocal insights from Argentina and Bulgaria
Trayectorias de los actores y construcción del campo de la ESS. Perspectivas cruzadas entre Argentina y Bulgaria
Mariyana AMOVA
This thesis focuses on the evolution of the SSE’s historical and emerging components and of the public actor, and the construction of SSE fields through their interplay in Argentina and Bulgaria. The research is based on an evolutionary analysis of the field applied to two case studies, allowing to shed light on the diversity of SSE construction processes within different contexts. The field is a notion which makes it possible to understand the relations between a set of actors. We approach the construction of the field of SSE as a process, which is the result of the dynamics of change of each actor in context, then of the intersections of those dynamics of change, producing the content of the field and the specific configuration of the links between actors. The theoretical framework relies on the principles of institutional change which are not based on the equilibrium approach, but seek to characterize the dynamics of continuity, discontinuity, and disruption. The theoretical approach specifically chosen for this research and applied to the Bulgarian and Argentinian cases is called contextual analysis. This theoretical framework makes it possible to grasp the change triggered by the asymmetries between levels of contexts. These asymmetries cause changes in the trajectories of the actors. The trajectories’ intersections in turn construct the field. It is a holistic approach which does not rely on single or multiple explanatory variables, but makes it possible to investigate why and how the SSE field emerges, without determining its content in advance. The two chosen countries provide a specific analytic perspective on different construction processes of the field. Argentina and Bulgaria are two countries whose social and economic contexts were affected by transitions and crises. These changes instilled a mobilization of the SSE components and the public actor in a different way in each country, allowing us to observe the recently engaged construction processes of SSE fields.
La investigación se centra en las trayectorias de los componentes históricos y emergentes de la economía social y solidaria (ESS) y del actor público, así como en la construcción de campos de la ESS a partir de sus interacciones en Bulgaria y Argentina. A través de un análisis evolutivo del campo aplicado a dos estudios de caso, la investigación permite iluminar la diversidad de procesos de construcción de la ESS dentro de contextos diferentes. El campo es una noción que permite comprender los vínculos entre un conjunto de actores. Abordamos la construcción del campo de la ESS como un proceso, resultado de las dinámicas de cambio de cada actor en su contexto, y luego de sus intersecciones que producen el contenido del campo y la configuración específica de los vínculos entre actores. Los dos países elegidos ofrecen un ángulo privilegiado para el estudio de diversos procesos. Argentina y Bulgaria fueron seleccionadas porque son dos ejemplos de países cuyos contextos socioeconómicos están marcados por crisis y transiciones. Estos cambios han movilizado a los actores de la ESS y a los actores públicos de manera singular en cada país, lo que permite observar los procesos recientes de construcción de campos de la ESS que se han iniciado.
La recherche porte sur les trajectoires des composantes historiques et émergentes de l'économie sociale et solidaire (ESS) et de l’acteur public et la construction de champs de l'ESS à partir de leurs interactions en Bulgarie et en Argentine. A travers une analyse évolutionnaire du champ appliquée à deux études de cas, la recherche permet d’éclairer la diversité de processus de construction de l’ESS au sein de contextes différents. Le champ est une notion qui permet d’appréhender les liens entre un ensemble d’acteurs. Nous abordons la construction du champ de l’ESS comme processus, résultat des dynamiques de changement de chaque acteur en contexte, puis de leurs intersections produisant le contenu du champ et la configuration spécifique des liens entre acteurs. Les deux pays choisis offrent un angle privilégié d’étude de processus variés. L’Argentine et la Bulgarie ont été choisies car ce sont deux exemples de pays dont les contextes socioéconomiques sont marqués par des crises et transitions. Ces changements ont mobilisé les acteurs de l’ESS et les acteurs publics de manière singulière à chaque pays, ce qui permet d’observer les processus récents de construction de champs de l’ESS qui se sont enclenchés.
AMOVA_these_finale.pdf (2.52 Mo) Télécharger le fichier
licence : CC BY ND - Paternité - Pas de modifications
tel-04558407 , version 1 (24-04-2024)
  • HAL Id : tel-04558407 , version 1
Mariyana AMOVA. Trajectoires des acteurs et construction du champ de l’ESS. Eclairages réciproques Argentine-Bulgarie. Sciences de l'Homme et Société. Université Paris Cité, 2020. Français. ⟨NNT : 2020UNIP7186⟩. ⟨tel-04558407⟩
Collections
REDIAL AAE-REVISTA
12 Consultations
2 Téléchargements
