Analysis of the energy harvesting performance of a piezoelectric bender outside its resonance - CRISTAL-MINT Accéder directement au contenu
Article Dans Une Revue Sensors and Actuators A: Physical Année : 2014
When the frequency of the source of vibration of a Piezolectric Generator is significantly different from its eigenfrequency, the dielectric power losses become prominent and decrease the amount of power which is practically harvested. For off-resonance vibrating frequencies, the optimal operating conditions can be obtained with a Maximum Power Point Tracking method. This paper introduces complex phasors in the study of power conversion for piezoelectric generators. These complex phasors are used to describe three strategies which help simplify the tracking of the optimal generator output power for vibration frequencies which are away from resonance. Experimental results obtained on a prototype illustrate and confirm the approach with the phasor approaches illustrate and confirm the success of the proposed optimal power tracking strategies. Finally, we show that the efficiency results of each strategy depend on whether they are used inside or outside a frequency bandwidth around the eigenfrequency, and that the length of this bandwidth depends on the excitation amplitude.
L2EP_BroadBandEH.pdf (526.58 Ko) Télécharger le fichier
hal-01044406 , version 1 (23-07-2014)
Adrian Amanci, Frédéric Giraud, Christophe Giraud-Audine, Michel Amberg, Francis Dawson, et al.. Analysis of the energy harvesting performance of a piezoelectric bender outside its resonance. Sensors and Actuators A: Physical , 2014, 217, pp.129-138. ⟨10.1016/j.sna.2014.07.001⟩. ⟨hal-01044406⟩
750 Consultations
496 Téléchargements
