Last deposits
Sergey Khoperskov, Ivan Minchev, Noam Libeskind, Vasily Belokurov, Matthias Steinmetz, et al.. The stellar halo in Local Group Hestia simulations III. Chemical abundance relations for accreted and in-situ stars. Astronomy and Astrophysics - A&A, 2023, 677, pp.A91. ⟨10.1051/0004-6361/202244234⟩. ⟨hal-03697603⟩
Pierre Palud, Pierre-Antoine Thouvenin, Pierre Chainais, Emeric E. Bron, Franck Le Petit. Problèmes inverses et test bayésien d'adéquation du modèle. 29° Colloque sur le traitement du signal et des images, GRETSI - Groupe de Recherche en Traitement du Signal et des Images, Aug 2023, Grenoble, France. pp.697 - 700. ⟨hal-04479586⟩
Pierre-Antoine Thouvenin, Audrey Repetti, Pierre Chainais. dsgs: a Distributed block-Split-Gibbs Sampler (DSGS) with hypergraph structure for high-dimensional inverse problems. 2023, ⟨swh:1:dir:0911fdbd8e7afd7e58cc02318148455f76e3233d;origin=https://hal.archives-ouvertes.fr/hal-04460733;visit=swh:1:snp:2e030045d796d6ca8ddbc01b2bacb9288d2710fe;anchor=swh:1:rel:942d5e3972252d4fb5127f24838afbeda05099c3;path=/⟩. ⟨hal-04460733⟩
