3D shaped mechanically flexible diamond microelectrode arrays for eye implant applications: The MEDINAS project Matrices d’électrodes en diamant pour l’interfaçage neuronal appliqué à la suppléance fonctionnelle (MEDINAS) - CV des membres de ESYCOM Access content directly
Journal Articles Innovation and Research in BioMedical engineering Year : 2011
P. Bergonzo
T. Kauffmann
  • Function : Author
F. Goy
  • Function : Author
The MEDINAS project aims at the fabrication of Micro-Electrode Arrays (MEA) that take advantage of a novel electrode material, namely synthetic conducting diamond, as the bio-interface material. Diamond enables the fabrication of electrodes with high biocompatibility, high electrochemical interfacing performances and long-term stability. The project aims at the development of diamond based MEAs for recording and stimulating of neuron networks for both in vitro applications (rigid substrate) as well as for in vivo retinal prostheses (flexible biocompatible substrate). The performances of this new technology were assessed as compared to standard metallic solutions.
article_PhilippeBergonzo_IRBM2011.pdf (307.76 Ko) Télécharger le fichier
Dates and versions
hal-00692916 , version 1 (28-06-2022)
Identifiers
Cite
P. Bergonzo, Alexandre Bongrain, Emmanuel Scorsone, A. Bendali, L. Rousseau, et al.. 3D shaped mechanically flexible diamond microelectrode arrays for eye implant applications: The MEDINAS project Matrices d’électrodes en diamant pour l’interfaçage neuronal appliqué à la suppléance fonctionnelle (MEDINAS). Innovation and Research in BioMedical engineering, 2011, 32 (2), pp.91--94. ⟨10.1016/j.irbm.2011.01.032⟩. ⟨hal-00692916⟩
185 View
44 Download
Share
