Denaturing mass photometry for straightforward optimization of protein-protein cross-linking reactions at single-molecule level - Département Recherches Subatomiques Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2023
Mass photometry (MP) is a versatile, fast and low sample-consuming biophysical technique that gained interest in structural biology to study noncovalent assemblies in native conditions. We report here on a novel method to perform MP analysis in denaturing conditions (dMP) and its application for fast, accurate and straightforward optimization of chemical reactions in cross-linking mass spectrometry (XL-MS) workflows. dMP consists in a robust 2-step protocol that ensures 95% of irreversible denaturation within only 5 min. The proposed single-molecule method clearly overcomes the limitations and outperforms gold standard SDS-PAGE, as illustrated on several biological complexes. dMP provides an unprecedented and unmatched in-solution quantification of all coexisting XL species, including sub-complexes and non-specific XL aggregates, along with identification of significantly higher numbers of XL dipeptides in MS. We anticipate single-molecule dMP to be a high-impact game-changer for the XL-MS community with the potential to leverage the quality and reliability of XL-MS datasets.
2023.05.30.542861v1.full.pdf (2.74 Mo) Télécharger le fichier
hal-04535064 , version 1 (05-04-2024)
Paternité - Pas d'utilisation commerciale - Pas de modification
  • HAL Id : hal-04535064 , version 1
Hugo Gizardin-Fredon, Paulo E Santo, Marie-Eve Chagot, Bruno Charpentier, Tiago M Bandeiras, et al.. Denaturing mass photometry for straightforward optimization of protein-protein cross-linking reactions at single-molecule level. 2024. ⟨hal-04535064⟩
24 Consultations
5 Téléchargements
