Fast compressive Raman micro-spectroscopy to image and classify microplastics from natural marine environment - Ecole Centrale de Marseille Accéder directement au contenu
Article Dans Une Revue Environmental Technology and Innovation Année : 2024
The fast and reliable detection of micron-sized plastic particles from the natural marine environment is an important topic that is mostly addressed using spontaneous Raman spectroscopy. Due to the long (>tens of ms) integration time required to record a viable Raman signal, measurements are limited to a single point per microplastic particle or require very long acquisition times (up to tens of hours). In this work, we develop, validate, and demonstrate a compressive Raman technology using binary spectral filters and single-pixel detection that can image and classify six types of marine microplastic particles over an area of 1 mm2 with a pixel dwell time down to 1.75 ms/pixel and a spatial resolution of 1 µm. This is x10–100 faster than reported in previous studies.
1-s2.0-S2352186424000981-main.pdf (11.02 Mo) Télécharger le fichier
licence : CC BY - Paternité
hal-04535494 , version 1 (11-04-2024)
Paternité
Clément Grand, Camille Scotté, Énora Prado, Maria El Rakwe, Olivier Fauvarque, et al.. Fast compressive Raman micro-spectroscopy to image and classify microplastics from natural marine environment. Environmental Technology and Innovation, 2024, 34, pp.103622. ⟨10.1016/j.eti.2024.103622⟩. ⟨hal-04535494⟩
36 Consultations
4 Téléchargements
