Role of non-ideality for the ion transport in porous media: derivation of the macroscopic equations using upscaling - Modélisation mathématique, calcul scientifique Accéder directement au contenu
Article Dans Une Revue Physica D: Nonlinear Phenomena Année : 2014
This paper is devoted to the homogenization (or upscaling) of a system of partial differential equations describing the non-ideal transport of a N-component electrolyte in a dilute Newtonian solvent through a rigid porous medium. Realistic non-ideal effects are taken into account by an approach based on the mean spherical approximation (MSA) model which takes into account finite size ions and screening effects. We first consider equilibrium solutions in the absence of external forces. In such a case, the velocity and diffusive fluxes vanish and the equilibrium electrostatic potential is the solution of a variant of Poisson-Boltzmann equation coupled with algebraic equations. Contrary to the ideal case, this nonlinear equation has no monotone structure. However, based on invariant region estimates for Poisson-Boltzmann equation and for small characteristic value of the solute packing fraction, we prove existence of at least one solution. To our knowledge this existence result is new at this level of generality. When the motion is governed by a small static electric field and a small hydrodynamic force, we generalize O'Brien's argument to deduce a linearized model. Our second main result is the rigorous homogenization of these linearized equations and the proof that the effective tensor satisfies Onsager properties, namely is symmetric positive definite. We eventually make numerical comparisons with the ideal case. Our numerical results show that the MSA model confirms qualitatively the conclusions obtained using the ideal model but there are quantitative differences arising that can be important at high charge or high concentrations.
1309.3679.pdf (1.83 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-00863442 , version 1 (31-01-2024)
Grégoire Allaire, Robert Brizzi, Jean-François Dufrêche, Andro Mikelic, Andrey Piatnitski. Role of non-ideality for the ion transport in porous media: derivation of the macroscopic equations using upscaling. Physica D: Nonlinear Phenomena, 2014, 282, pp.39-60. ⟨10.1016/j.physd.2014.05.007⟩. ⟨hal-00863442⟩
602 Consultations
14 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
