Cross-sensor super-resolution of irregularly sampled Sentinel-2 time series - Institut national de l’information géographique et forestière - Ecole nationale des sciences géographiques Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
Satellite imaging generally presents a trade-off between the frequency of acquisitions and the spatial resolution of the images. Super-resolution is often advanced as a way to get the best of both worlds. In this work, we investigate multi-image super-resolution of satellite image time series, i.e. how multiple images of the same area acquired at different dates can help reconstruct a higher resolution observation. In particular, we extend state-of-the-art deep single and multi-image super-resolution algorithms, such as SRDiff and HighRes-net, to deal with irregularly sampled Sentinel-2 time series. We introduce BreizhSR, a new dataset for 4x super-resolution of Sentinel-2 time series using very high-resolution SPOT-6 imagery of Brittany, a French region. We show that using multiple images significantly improves super-resolution performance, and that a well-designed temporal positional encoding allows us to perform super-resolution for different times of the series. In addition, we observe a trade-off between spectral fidelity and perceptual quality of the reconstructed HR images, questioning future directions for super-resolution of Earth Observation data.
main.pdf (3.32 Mo) Télécharger le fichier
hal-04552850 , version 1 (22-04-2024)
Aimi Okabayashi, Nicolas Audebert, Simon Donike, Charlotte Pelletier. Cross-sensor super-resolution of irregularly sampled Sentinel-2 time series. EARTHVISION 2024 IEEE/CVF CVPR Workshop. Large Scale Computer Vision for Remote Sensing Imagery, Jun 2024, Seattle, United States. ⟨hal-04552850⟩
27 Consultations
12 Téléchargements
