Spin Fluctuations Drive the Inverse Magnetocaloric Effect in Mn 5 Si 3 - INAC-SPSMS Accéder directement au contenu
Article Dans Une Revue Physical Review Letters Année : 2018
Inelastic neutron scattering measurements are performed on single crystals of the antiferromagnetic compound Mn5Si3 in order to investigate the relation between the spin dynamics and the magnetothermodynamics properties. It is shown that, among the two stable antiferromagnetic phases of this compound, the high temperature one has an unusual magnetic excitation spectrum where propagative spin waves and diffuse spin fluctuations coexist. Moreover, it is evidenced that the inverse magnetocaloric effect of Mn5Si3, the cooling by adiabatic magnetization, is associated with field induced spin fluctuations.
1802.07511.pdf (1.23 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01899008 , version 1 (01-03-2024)
N. Biniskos, K. Schmalzl, S. Raymond, S. Petit, P. Steffens, et al.. Spin Fluctuations Drive the Inverse Magnetocaloric Effect in Mn 5 Si 3. Physical Review Letters, 2018, 120 (25), pp.257205. ⟨10.1103/PhysRevLett.120.257205⟩. ⟨hal-01899008⟩
81 Consultations
5 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
