The EUV Sun as the superposition of elementary Suns - Analyse et Décision en Traitement du Signal et Images Access content directly
Journal Articles Astronomy and Astrophysics - A&A Year : 2008
Aims. Many studies assume that the solar irradiance in the EUV can be decomposed into different contributions, which makes modelling the spectral variability considerably easier. We consider a different approach in which these contributions are not imposed a priori but effectively and robustly inferred from spectral irradiance measurements. Methods. This is a source separation problem with a positivity constraint, for which we use a Bayesian solution. Results. Using five years of daily EUV spectra recorded by the TIMED/SEE satellite, we show that the spectral irradiance can be decomposed into three elementary spectra. Our results suggest that they describe different layers of the solar atmosphere rather than specific regions. The temporal variability of these spectra is discussed.
aa09588-08.pdf (205.57 Ko) Télécharger le fichier
Origin : Publisher files allowed on an open archive
Dates and versions
hal-00325235 , version 1 (27-11-2019)
Identifiers
Cite
Pierre-Olivier Amblard, Saïd Moussaoui, Thierry Dudok de Wit, Jean Aboudarham, Matthieu Kretzschmar, et al.. The EUV Sun as the superposition of elementary Suns. Astronomy and Astrophysics - A&A, 2008, 487, pp.L13-L16. ⟨10.1051/0004-6361:200809588⟩. ⟨hal-00325235⟩
343 View
45 Download
Share
