Estimating traffic noise levels using acoustic monitoring: a preliminary study - Analyse et Décision en Traitement du Signal et Images Accéder directement au contenu
In this paper, the Non-negative Matrix Factorization is applied for isolating the contribution of road traffic from acoustic measurements in urban sound mixtures. This method is tested on simulated scenes to enable a better control of the presence of different sound sources. The presented first results show the potential of the method.
doc00025835.pdf (735.98 Ko) Télécharger le fichier
hal-01375796 , version 1 (03-10-2016)
  • HAL Id : hal-01375796 , version 1
Jean-Rémy Gloaguen, Arnaud Can, Mathieu Lagrange, Jean-François Petiot. Estimating traffic noise levels using acoustic monitoring: a preliminary study. DCASE 2016, Detection and Classification of Acoustic Scenes and Events, Sep 2016, BUDAPEST, Hungary. 4p. ⟨hal-01375796⟩
274 Consultations
164 Téléchargements
