Numerical Tools for Geometric Optimal Control and the Julia control-toolbox package - Algorithmes Parallèles et Optimisation Accéder directement au contenu
Chapitre D'ouvrage Année : 2024
We present in this article numerical techniques — the Julia control-toolbox package — for computing geometric optimal control concepts: Hamiltonian flows associated to the optimal control problem, Jacobi flows, Poisson brackets of Hamiltonians to define the singular control associated to a singular arc, etc. With these tools, it becomes easy to solve an optimal control problem by indirect methods, and to compute conjugate times together with the cut locus. We present the numerical tools on two test bed examples: the surface of revolution of minimum area and the Goddard problem. The first problem comes from calculus of variations and thus is regular. We also compute the conjugate locus for this example. On the other hand, the optimal solution of the Goddard problem contains bang and singular arcs.
2024-CG-preprint.pdf (1.11 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-04578955 , version 1 (17-05-2024)
  • HAL Id : hal-04578955 , version 1
Olivier Cots, Joseph Gergaud. Numerical Tools for Geometric Optimal Control and the Julia control-toolbox package. Bernard Bonnard; Monique Chyba; David Holcman; Emmanuel Trélat. Ivan KUPKA LEGACY: A Tour Through Controlled Dynamics, 58 (chapter 10), AIMS Sciences, pp.209--243, 2024, AIMS on Applied Mathematics, 978-1-60133-026-0. ⟨hal-04578955⟩
0 Consultations
0 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
