CD-GAN: A robust fusion-based generative adversarial network for unsupervised remote sensing change detection with heterogeneous sensors - Signal et Communications Access content directly
Journal Articles Information Fusion Year : 2024
In the context of Earth observation, change detection boils down to comparing images acquired at different times by sensors of possibly different spatial and/or spectral resolutions or different modalities (e.g., optical or radar). Even when considering only optical images, this task has proven to be challenging as soon as the sensors differ by their spatial and/or spectral resolutions. This paper proposes a novel unsupervised change detection method dedicated to images acquired by such so-called heterogeneous optical sensors. It capitalizes on recent advances which formulate the change detection task into a robust fusion framework. Adopting this formulation, the work reported in this paper shows that any off-the-shelf network trained beforehand to fuse optical images of different spatial and/or spectral resolutions can be easily complemented with a network of the same architecture and embedded into an adversarial framework to perform change detection. A comparison with state-of-the-art change detection methods demonstrates the versatility and the effectiveness of the proposed approach.
manuscript.pdf (2.11 Mo) Télécharger le fichier
Dates and versions
hal-04483118 , version 1 (29-02-2024)
Attribution
Identifiers
Cite
Jin-Ju Wang, Nicolas Dobigeon, Marie Chabert, Ding-Cheng Wang, Ting-Zhu Huang, et al.. CD-GAN: A robust fusion-based generative adversarial network for unsupervised remote sensing change detection with heterogeneous sensors. Information Fusion, 2024, 107, pp.102313. ⟨10.1016/j.inffus.2024.102313⟩. ⟨hal-04483118⟩
65 View
7 Download
Share
