Multi-class Neural Additive Models : An Interpretable Supervised Learning Method for Gearbox Degradation Detection - Equipe diagnostic, supervision et COnduite Access content directly
Conference Papers Year : 2024
This paper introduces the Multi-class Neural Additive Models (MNAMs), an extension of Neural Additive Models (NAMs) designed to solve multi-class classification problems while remaining interpretable. The paper firstly presents a set of definitions around model interpretability and associated concepts, concepts on which the proposed machine learning method relies on. The core of the contribution lies in the development of MNAM, a model training method designed to minimize the traditional trade-off between accuracy and interpretability. This method is then put to test in a concrete application: the detection of gearbox degradation levels using vibration data, as part of the PHM Society data challenge of 2023. The obtained results demonstrate that a MNAM reaches higher accuracy performance than other interpretable methods such as Decisional Tree (DT) or Generalized Additive Models (GAMs).
Multi-class Neural Additive Models An Interpretable Supervised Learning Method for Gearbox Degradation Detection.pdf (4.52 Mo) Télécharger le fichier
Dates and versions
hal-04562531 , version 1 (02-05-2024)
Identifiers
  • HAL Id : hal-04562531 , version 1
Cite
Charles-Maxime Gauriat, Yannick Pencolé, Pauline Ribot, Gregory Brouillet. Multi-class Neural Additive Models : An Interpretable Supervised Learning Method for Gearbox Degradation Detection. 2024 IEEE International Conference on Prognostics and Health Management, Jun 2024, Spokane WA, United States. ⟨hal-04562531⟩
0 View
0 Download
Share
