Performance Analysis of Space Shift Keying (SSK) Modulation with Multiple Cooperative Relays - Laboratoire des Sciences et Techniques de l'Information, de la Communication et de la Connaissance, site ENIB Brest Accéder directement au contenu
Article Dans Une Revue EURASIP Journal on Advances in Signal Processing Année : 2011
In this article, space shift keying (SSK) modulation is used to study a wireless communication system when multiple relays are placed between the transmitter and the receiver. In SSK, the indices of the transmit antennas form the constellation symbols and no other data symbol are transmitted. The transmitter and the receiver communicate through a direct link and the existing relays. In this study, two types of relays are considered. Conventional amplify and forward relays in which all relays amplify their received signal and forward it to the destination in a round-robin fashion are considered. In addition, decode and forward relays in which the relays that correctly detect the source signal will forward the corresponding fading gain to the destination in pre-determined orthogonal time slots are studied. The optimum decoder for both communication systems are derived and performance analysis are conducted. The exact average bit error probability (ABEP) over Rayleigh fading channels is obtained in closed-form for a source equipped with two transmit antennas and arbitrary number of relays. Furthermore, simple and general asymptotic expression for the ABEP is derived and analyzed. Numerical results are also provided, sustained by simulations which corroborate the exactness of the theoretical analysis. It is shown that both schemes perform nearly the same and the advantages and disadvantages of each are discussed
1687-6180-2012-201.pdf (430.54 Ko) Télécharger le fichier
hal-00802477 , version 1 (27-02-2024)
Raed Mesleh, Salama S. Ikki, El-Hadi Aggoune, Ali Mansour. Performance Analysis of Space Shift Keying (SSK) Modulation with Multiple Cooperative Relays. EURASIP Journal on Advances in Signal Processing, 2011, 2012, pp.201. ⟨10.1186/1687-6180-2012-201⟩. ⟨hal-00802477⟩
183 Consultations
10 Téléchargements
