Blind identification of code word length for non-binary error-correcting codes in noisy transmission - Laboratoire des Sciences et Techniques de l'Information, de la Communication et de la Connaissance, site ENIB Brest Accéder directement au contenu
Article Dans Une Revue EURASIP Journal on Wireless Communications and Networking Année : 2015
Yasamine Zrelli
  • Fonction : Auteur
  • PersonId : 919604
Roland Gautier
Mélanie Marazin
Emanuel Radoi
In cognitive radio context, the parameters of coding schemes are unknown at the receiver. The design of an intelligent receiver is then essential to blindly identify these parameters from the received data. The blind identification of code word length has already been extensively studied in the case of binary error-correcting codes. Here, we are interested in non-binary codes where a noisy transmission environment is considered. To deal with the blind identification problem of code word length, we propose a technique based on the Gauss-Jordan elimination in GF(q) (Galois field), with q=2m, where m is the number of bits per symbol. This proposed technique is based on the information provided by the arithmetic mean of the number of zeros in each column of these matrices. The robustness of our technique is studied for different code parameters and over different Galois fields.
s13638-015-0294-5.pdf (915.68 Ko) Télécharger le fichier
Origine Fichiers éditeurs autorisés sur une archive ouverte
hal-01131852 , version 1 (27-02-2024)
Yasamine Zrelli, Roland Gautier, Eric Rannou, Mélanie Marazin, Emanuel Radoi. Blind identification of code word length for non-binary error-correcting codes in noisy transmission. EURASIP Journal on Wireless Communications and Networking, 2015, 2015 (1), pp.2015:43. ⟨10.1186/s13638-015-0294-5⟩. ⟨hal-01131852⟩
150 Consultations
5 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
