Fewer Cores, More Hertz: Leveraging High-Frequency Cores in the OS Scheduler for Improved Application Performance - ERODS Access content directly
Conference Papers Year : 2020
In modern server CPUs, individual cores can run at different frequencies, which allows for fine-grained control of the per-formance/energy tradeoff. Adjusting the frequency, however, incurs a high latency. We find that this can lead to a problem of frequency inversion, whereby the Linux scheduler places a newly active thread on an idle core that takes dozens to hundreds of milliseconds to reach a high frequency, just before another core already running at a high frequency becomes idle. In this paper, we first illustrate the significant performance overhead of repeated frequency inversion through a case study of scheduler behavior during the compilation of the Linux kernel on an 80-core Intel R Xeon-based machine. Following this, we propose two strategies to reduce the likelihood of frequency inversion in the Linux scheduler. When benchmarked over 60 diverse applications on the Intel R Xeon, the better performing strategy, S move , improves performance by more than 5% (at most 56% with no energy overhead) for 23 applications, and worsens performance by more than 5% (at most 8%) for only 3 applications. On a 4-core AMD Ryzen we obtain performance improvements up to 56%.
atc20-gouicem.pdf (3.55 Mo) Télécharger le fichier
Dates and versions
hal-02901169 , version 1 (16-07-2020)
Identifiers
  • HAL Id : hal-02901169 , version 1
Cite
Redha Gouicem, Damien Carver, Jean-Pierre Lozi, Julien Sopena, Baptiste Lepers, et al.. Fewer Cores, More Hertz: Leveraging High-Frequency Cores in the OS Scheduler for Improved Application Performance. 2020 USENIX Annual Technical Conference, USENIX, Jul 2020, Boston / Virtual, United States. ⟨hal-02901169⟩
248 View
383 Download
Share
