Spy On Your Models
EMF is now widely used by various kinds of systems based on Eclipse Modeling Project components. As EMF models become the heart of these systems, it becomes critical to be able to inspect them very precisely. It is the main objective of the MoDisco Model Browser to provide a good insight of the content of any EMF model, especially when these models are large and complex. This talk will present the main features of this tool: 1) Directly access to instances of a given EClass 2) Navigate through the relations between model elements 3) Dynamically customize the rendering of model elements 4) Edit the model elements with a tabular view 5) Integrate the browser components with the Common Navigation Framework
Informatique et langage [cs.CL]
