EMF Views: Dealing with several interrelated EMF models - ATLANMOD Accéder directement au contenu
Users only need to see some parts of an EMF model, others have to get the full model extended with data from another model, and others simply access to a combination of information coming from different models. Based on the unquestionable success and usefulness of database views to solve similar problems in the database world, EMF Views aims to bring the same concepts to the modeling world. This short talk is going to introduce the current version of EMF Views, notably showing different possible applications of model views such as Software developer views, enterprise architect views, view querying or transformation.
emfviews-modelingsymposium-ecna2014.pdf (1.03 Mo) Télécharger le fichier
hal-00974711 , version 1 (11-04-2023)
  • HAL Id : hal-00974711 , version 1
Hugo Bruneliere, Juan David Villa Calle. EMF Views: Dealing with several interrelated EMF models. EclipseCon 2014 - Modeling Symposium, Mar 2014, San Francisco, United States. ⟨hal-00974711⟩
300 Consultations
1 Téléchargements
